Whats next to get 500+RWHP
Old Oct 21, 2008 | 11:16 AM
Mopar Man's Avatar
Default Whats next to get 500+RWHP
Ok guys I am in the quest to hit 500+RWHP I know im getting close with the mods in my sig. I dont know what my exact # is with the edge turned all the way up to lvl 6 But Im guessing I should be @ 450+ RWHP. I have only done 1 Dyno run and that was on power lvl 3 (my daily driver setting) and it layed down 403.3 RWHP with 37" tires & 3.55 gears. What would you guys recomend/sudgest to get me to break the 500RWHP mark TIA.
Old Oct 23, 2008 | 09:35 AM
Mopar Man's Avatar
No one has any input on this
Old Oct 23, 2008 | 12:59 PM
DIESELDENT's Avatar
bigger injector and a smarty, smarty add's more power and run cooler.
Old Oct 23, 2008 | 01:57 PM
Mopar Man's Avatar
I heard that when you stack the smarty with an edge it adds fuel witch in turn creates hotter EGT's. Is this not correct?
Old Oct 23, 2008 | 02:20 PM
DIESELDENT's Avatar
how hot are you getting now? i was saying just the smarty, youll get real got with that stack. when ever you add fuel you have to add a more air how bigs your turbo?
Old Oct 23, 2008 | 03:20 PM
Mopar Man's Avatar
My turbo is basicly a 64/71 I can get a little worm right now but temps are still prety manageable.
Old Oct 25, 2008 | 10:18 PM
akdiesel97's Avatar
Instead of buying all new injectors you can just get tips for them wich cut the cost alot. Also some sort of injection would do a bit, ive only experimented with propane but it seemed to give me a lil more power and alot of people say good things about it. They sell 100hp kits for the propane but theres always water meth, or you could go for the nose kandy noss. I've always wondered what would happen if you duct taped a can of starting fluid to your air intake and put a string connected to it inside the cab. But dont try that you'll have a dead engine.
Old Oct 25, 2008 | 10:32 PM
biged681985's Avatar
at the starting fluid
Old Oct 26, 2008 | 08:45 AM
SmokinPiney's Avatar
I don't know about the higher egt's but when my buddy was runnin his smarty on top of the edge it just didn't run as well as it did without the smarty. Probly due to the extra fuel? He's pushin over 500hp but he has 200hp DDP's and a custom vp44.
Swap out those 120's for some 200's then see what your makin . Also try a water/meth kit. Oh and put that edge on level 6 next time ya run. You won't believe the difference it'll make.
Old Oct 26, 2008 | 10:24 AM
dieselbeef's Avatar
trade it for a duramax......
