Check Engine Light came on
Old Oct 19, 2008 | 07:19 PM
MegaMan's Avatar
Default Check Engine Light came on
I've been searching on here for a little while and can't find the answer to my question. I know there are a lot of posts like this but I need help so here goes:
Truck threw a CEL this morning. First time ever at 38,600 miles. I changed the oil and fuel filter (Baldwin filter) on Friday, this morning was the third time I started it since changing the filter and it threw the light. It was about 55 degrees here this morning, the grid heater came on, I started the engine, it died, started right back up, threw the light. Went ahead and drove down the road, ran fine, no problems.
My only mods are Afe intake, 5" turbo back exhaust, and Quadzilla mileage module with boost fool. I am running Power Service in my fuel in every other tank.
I did the key flip thing, no codes show up in the odometer area but the CEL flashes 10 times. This is my first go at the CEL thing so I'm dumb.
Please help!
Old Oct 19, 2008 | 07:23 PM
DB Admin's Avatar
Banned
Stop by Autozone and get your truck scanned for codes
https://www.dieselbombers.com/codes.php
Old Oct 20, 2008 | 10:49 AM
steved's Avatar
Check the codes. You can buy a cheap code reader/code eraser for $60 from Harbor Freight (a good investment).
If it was an 03-04, I'd say classic lift pump failure symptoms. But the 05+ aren't affected the same way by a lift pump failure...
Old Oct 20, 2008 | 01:11 PM
MegaMan's Avatar
Y'all say check the codes but what does the key flip thing do? Won't that bring up codes? I don't get any codes from doing that check. Didn't think about the Harbor Freight scanner. I'll get one of those, you're right, good investment.
The first thing I thought was lift pump but at 38k miles?
Old Oct 20, 2008 | 01:14 PM
steved's Avatar
I think the key flipping only tests the dash, doesn't do anything for codes.
I thought lift pump, but yours is in the tank...
Old Oct 20, 2008 | 01:24 PM
DB Admin's Avatar
Banned
Need to scan for the codes
Old Oct 23, 2008 | 06:05 PM
MegaMan's Avatar
O.k. I bought a scanner and checked it out. One code: P0191 - fuel rail pressure. Everybody pretty much said the same thing: lift pump BUT then said that the 06 is in the tank, which it is. Guess it's time for a fuel pressure gauge. Could this have just been a fluke after I changed the fuel filter or is my lift pump going out at 38k miles?
I cleared the CEL, will see if it stays off, guess that will answer my question.
I want to know about how to install a fuel pressure gauge, I'll start a new thread.
Old Oct 23, 2008 | 06:11 PM
steved's Avatar
Clear it and see if comes back...
They make a fuel filter cap that is drilled and tapped for a sending unit...
Old Oct 23, 2008 | 06:13 PM
DB Admin's Avatar
Banned
Probably from when you changed your fuel filter
Old Oct 23, 2008 | 08:24 PM
MegaMan's Avatar
Steved, tell me more about the fuel filter cap, where can I find it?
