HP #'s
Old Oct 17, 2008 | 10:50 PM
LittleRed's Avatar
Default HP #'s
What kind of number could be I looking for with the following mods:
Drag Comp/Smarty Revo
Jammer 4's
BHAF
6" Stack
Fuel System
62/71/13
Old Oct 18, 2008 | 04:13 PM
crazytexan's Avatar
With a 62 charger,Jammer 4's TST comp and smarty I hit 427. I also had the fuel system and exhaust to. I'd guess around there.
Old Oct 21, 2008 | 02:19 PM
dukeboy_318's Avatar
id say between 400-450 at rear wheels depending on trans of course, with my set up listed in my signature, i constantly get 450-500 depending on the dyno.
Old Oct 21, 2008 | 04:21 PM
LittleRed's Avatar
Yeah I have a nv4500 with SB 3600, DukeBoy do you have a different charger then?
Old Oct 22, 2008 | 07:49 AM
nope, stock turbo and 4 in straight pipe into a 5 in exit. I have adjusted the wastegate and put a boost elbow on that came with my edge juice. I can hit 43 lbs of boost on the dyno, that seems to be the max i can get right now. my egts are around 1150-1300 at WOT on the dyno, crusing egts are around 700 at 75 mph.
Old Oct 22, 2008 | 09:35 AM
turbomar's Avatar
Thumbs up
am surprised 2 c that much boost Dukeboy. r u sure ur wastegate isn't seized? mine was seized shut a while back and the biggest boost # I'v seen was 35psi with stock injectors. Since then, I got a banks Quick turbine housing, that takes care of the smoke @ lower revs
Old Oct 22, 2008 | 12:16 PM
kazairl's Avatar
My hx-35 will hit 40 psi however its pretty toasty at that level.
Old Oct 23, 2008 | 10:01 AM
no, it aint siezed at all. works fine. btw, i aint running stock injectors either
Old Oct 26, 2008 | 07:17 PM
LittleRed's Avatar
My 35 can see up to 50 if I let it, Its been there a few times. Im always scared that shes gonna pop though. Im supposed to get my truck on the rollers pretty soon, so I guess ill see what it will do with the 62 on it. Ill keep you posted.
Old Oct 26, 2008 | 08:12 PM
underpressure!'s Avatar
since ya'll are talking bout hp#'s....by looking at my sig what do you think I might put down. I always want to get on the rollers but never get time to!
