Double Deep Tranny pan
Old Oct 14, 2008 | 04:02 PM
06MegaCab's Avatar
Default Double Deep Tranny pan
im thinking about installing a double deep tranny pan in my 06 2500 megacab......is there gonna be any clearance issues? also am i gonna have to do anything other than drain fluid replace gasket and replace pan?
Old Oct 14, 2008 | 04:58 PM
wildbill's Avatar
I'd go ahead and replace the filter while you got the pan off. I've got one that holds One extra gallon, and it's about flush w/ the t-case x-member. Your will probably go past about a couple inches.
Old Nov 13, 2008 | 01:00 PM
madhat's Avatar
You should not need to replace the gasket unless it's damaged. They are reuseable.
Old Nov 13, 2008 | 02:00 PM
mikmaze's Avatar
if that is a 48re, search for a deal on a 727 tranny pan, same thing but tends to cost less than a 48 re pan. 48re has been likend to the 727 with the added on overdrive unit.
Old Nov 14, 2008 | 12:52 AM
06MegaCab's Avatar
well i bolted it up took less than an hour easy upgrade
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
Ol' RED!
Dec 11, 2014 10:00 AM
