push rod talk
Old Oct 13, 2008 | 11:59 AM
CTD03's Avatar
Default push rod talk
push rod talk
whats the limit of stockers
whats every one run and how have they held up to the 4000 tunes
Old Oct 13, 2008 | 12:16 PM
stkdram55's Avatar
i think the biggest thing with running a 4000K tune is your valve springs you need atleast 60 pounders and it think your stock pushrods will be fine with just 60# springs but once ya go over that you should look into HD pushrods
Old Oct 14, 2008 | 12:59 PM
CTD03's Avatar
Mr Hamilton told me running a mild 650hp i would be fine. i hope my truck makes 650 hp
so i really dont know what hp you need to changed them out at
Old Oct 31, 2008 | 09:14 PM
dieselram_04's Avatar
i was kinda wondering the same myself i am upgrading my cam springs and putting studs in while im at it
Old Nov 2, 2008 | 09:24 PM
Luvnacummins's Avatar
STock push rods are very healthy... IMO I wouldn't waste the time and money it putting billet ones in unless you are going to have a dedicated sled puller or track truck.. WHY... you need a weak link in your motor.. TO run the 4k tune all's you need is the valve springs. Hamilton's are what I installed and they work flawlessly.. But if you have a cam, springs, and push rods everything in the motor is built and has no weak point.. Getting back to the push rods if you bend a push rod they are easier to replace and work on than per say dropping a valve or bending your crank....
I believe LLoyd mills and tim barber at one time were running all stock pushrods and still mmight be...
gunman41mag
The Sportsmen's Lounge
Sep 22, 2015 07:10 AM
Jul 28, 2015 03:50 AM
67IH
Jun 25, 2015 07:53 AM
woodsman27
Dec 9, 2014 09:55 AM
