Water Meth
Old Oct 12, 2008 | 10:00 PM
WyoD-MAX's Avatar
Default Water Meth
ok so i kinda know how its supposed to wrok but when tuning what exactly should i be watching for if i bought and purchased i know there is alot of varieties with nozzles and pump and psi of boost but do i just watch my egt temps to drop and tune off of that or does anyone know how im supposed to achieve optimum performance without messing to much up. . .
Old Oct 12, 2008 | 11:11 PM
Camotanker's Avatar
in a nut shell... from your sig...
you should see an decent amount of cooling/power increase vs alot of the heavily modified trucks out there who seem to get very little out of the package.
rule number 1. you can run 50% more volume using a 50/50 mix vs straight water. so keep that in mind when picking your nozzels. i found i had to use seperate nozzels for just water and bigger nozzels for 50/50.
rule number 2. do not use windshield wiper fluid that protects below -20 degrees and do not use anything with propalyne glycol. the -20 degree blue stuff is perfect. you can pull msds saftey sheets online. propalyne glycol will not compress and will have more of an effect of blowing gaskets. i know.
rule number 3. if you notice a "knocking" when spraying, use a smaller nozzel or adjust settings. this is known as "quenching" and is putting the fire out. bad. too much volume. you may also hear alot of timing. again, bad. use smaller nozzel or adjust settings. a properly running kit you will not notice any engine noise change. you should feel the increase slightly if tuned right and possible egt reduction.
Old Oct 19, 2008 | 09:12 PM
Camotanker's Avatar
so any update?
Old Oct 19, 2008 | 10:07 PM
WyoD-MAX's Avatar
ya it turned into more of a project than i had planned i mounted everything up snd was tightening a nut up on the alternator because i had to move this wire for a different angke but i ended up dropping my wrench and it fell in a gap ended up going under the turbo housing i havent had a chance to test it yet cause its pretty laate here but i wil let you know how it goes...
Aug 27, 2015 04:00 PM
Levi2320
Mar 15, 2015 12:05 PM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
89ezgo
Dec 9, 2014 08:58 PM
yams
Dec 7, 2014 12:51 PM
