Fuel Pressure Sender For The Adrenaline/Pulse
Old Oct 8, 2008 | 10:05 PM
Marine's Avatar
Default Fuel Pressure Sender For The Adrenaline/Pulse
Does anyone know the specs needed for the sender to allow the FP to read on the pulse?
Old Oct 9, 2008 | 01:29 AM
2500HeavyDuty's Avatar
i coudnt find any instructions on the pulse monitor online
Old Oct 9, 2008 | 08:49 AM
Marine's Avatar
I have a Nordskog gauge and it requires a sender that is 240-33 ohm and 0-16#. I was just wondering if anyone knew if that will work with the ADR.
Old Oct 9, 2008 | 07:21 PM
kazairl's Avatar
The sending unit we utilize is a 0-40psi resistive type fuel pressure sender, oil sender will work but longevity may be a concern. Ohm range is 240-33ohms. Keep in mind that the
closer to a 0-40psi unit that you can find the more accurate it will be, if you use a 80psi for example it will most likely read slightly too high. Stewart Warner or ISSPRO are viable options, worth looking into. Please understand we will try to do anything we can, we just don't want to sell you guys junk sending units, and why this has been drug out so long. Please contact us anytime with your feedback or questions.
Justin Tollefson
Technician
Quadzilla Performance Technologies
TEL 1-888-842-6572
FAX 1-817-306-3872
jtollefson@quadzillapower.com
Diesel Performance | Quadzilla Performance | Diesel Truck
That was the reply from Quadzilla to a member's question on another thread on TDR.
Old Oct 9, 2008 | 07:27 PM
Marine's Avatar
Thanks!
Old Oct 9, 2008 | 09:09 PM
kazairl's Avatar
Make sure you get a pressure snubber too. I know autometer sells one. Or an orifice or a needle valve that is pinched down. Something to dampen the pressure pulses. I installed my FP guage without one and trashed my sender within a couple weeks. Maybe someone has come up with a better idea to fix it? I don't know but senders are expensive. I'd rather not see someone repeating my mistake.
Old Oct 9, 2008 | 09:16 PM
Marine's Avatar
I have mine mounted to the bottom of the fuel canister, so the pulses should not be bad there.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
