Overboost Code??? How?
Old Oct 6, 2008 | 12:14 AM
Renteria1217's Avatar
Default Overboost Code??? How?
The other day I ran a scan to check on things and an overboost code came up. I have no real mods yet installed on my truck besides a BD fuel pump. How could I overboost? Earlier that day I did have the truck in 4low and I went up a muddy hill kind of on it just to make it up. Could that have been it?
Old Oct 7, 2008 | 01:53 AM
Anyone?
Old Oct 7, 2008 | 02:07 AM
Ed ke6bnl's Avatar
I know you said you have not add ons but we had an over boost with a defective edge EZ took a couple of day to find out after testing everything. Probable a faulty Map sensor. Ed
Old Oct 7, 2008 | 02:47 PM
Was it the MAP sensor on yours or was it the chip? If the MAP sensor was bad, wouldn't that come up as a different code for itself?
Old Oct 7, 2008 | 03:03 PM
wildbill's Avatar
You would get an underboost or MAP sensor voltage too low code
Old Oct 7, 2008 | 05:39 PM
Fishin2Deep4U's Avatar
Bad MAP sensors can produce both codes of too high of boost and too low.
Dave
Old Oct 8, 2008 | 10:04 AM
I cleared the code after the scan. So if it continues to come back, should I change my MAP sensor then?
Old Oct 8, 2008 | 03:18 PM
turbomar's Avatar
Exclamation
Before u go and get a map sensor, I would hook up a mechanical gauge and c if ur getting 25-30 psi. Also, the waste gate tends 2 seize. this happened on mine and boost maxes out at about 40 psi but still didn't generate a "too high boost code"
Old Oct 8, 2008 | 04:51 PM
I thought it was at 22 psi that you get a boost code. How could the turbo push 40 psi on a pretty much stock truck? I didn't know that was possible. With no mods is it possible to overboost to the point of engine damage?
Old Oct 8, 2008 | 05:34 PM
turbomar's Avatar
[QUOTE=Renteria1217;221525]I thought it was at 22 psi that you get a boost code. How could the turbo push 40 psi on a pretty much stock truck? I didn't know that was possible. With no mods is it possible to overboost to the point of engine damage?[/QUOTE
ur boost would certainly go higher if ur waste gate was seized. How high depends on what fuel amount is being injected. In my case, I have the edge juice with power level 6. If in ur case, if u r stock, u wont reach that value. With no mods, I hardly think u would reach 30 psi with waste gate seized.
