CHECK THIS OUT...Use A 727 Torqueflight Tranny Pan For 47RE...REALLY???
Old Oct 5, 2008 | 03:53 PM
Renteria1217's Avatar
Default CHECK THIS OUT...Use A 727 Torqueflight Tranny Pan For 47RE...REALLY???
I recently have been doing alot of research on these trucks. I bought mine about a month ago and want to learn as much as possible. I am going to be puting a deeper trannsmission pan w/ plug on it. While researching I've found that a pan off of an old 727 torqueflight tranny will fit the 47RE tranny as well, well it should from what I've read, haven't tried yet. Anyways...You can buy a deep replacement pan for a 727 torqueflight for about $20 plus shipping. That was the cheapest I found. Now I don't know how much more fluid it holds, but it's 3" deep so I do believe it holds more and it has a plug, oh and it comes chrome. I'm thinking instead of spending $200-$300 on an upgraded pan for my 47RE, why wouldn't I just spend $20 for this one and still have a better pan than my stock one? Anyone have any input on this???
Old Oct 5, 2008 | 05:41 PM
HOTMOPR's Avatar
same pan. Alot of internals are the same as well.. until you get to the OD.
Old Oct 5, 2008 | 05:46 PM
Red_Rattler's Avatar
High Tech Redneck
Yup same design with an hydraulic or electronic OD unit added to the rear end of it!
Old Oct 5, 2008 | 06:52 PM
01quadcab's Avatar
they use the same pan but once you get to the 48 it's a stock replacement on the deep pans that fit the 727. only about 1/2 qt bigger for the 47re. but yes they are cheaper than buying a mag or similar pan and you get a drain plug. I have the b&m on mine.
Old Oct 5, 2008 | 08:59 PM
Cool. So its the deep pan for the 727 that's 1/2 quart bigger, or is it just the stock replacment pan that's 1/2 quart bigger? I know you can buy both a regualr replacment and a deep replacement. Also I'm pretty sure I have the 47re, but how do I check it?
Old Oct 5, 2008 | 10:49 PM
01quadcab's Avatar
The 48re came into play in the 3rd gens. the deep pan for a 727 only adds 1/2 qt well atleast the one I got did. B&M 10280 - B&M Automatic Transmission Deep Pans - summitracing.com says 4qts for all other aps but this pan was just put on a buddies 00 and they said only 1/2qt more but it's aluminum and has a drain plug
Old Oct 5, 2008 | 11:55 PM
The deep pan I was looking at for the 727 was 3" deep. The one you've got says 3 3/8" deep. I don't think the stock one on my 47re is quite 3" deep. I would think the 3" deep pan would add atleast 1/2 quart or so to the 47re. Yours should add more than 1/2 quart. How did the new one look compared to the old one, depth wise? I'm just thinking if 3 3/8" deep only adds half quart, then maybe the $20 3" deep pan I was looking at isn't deeper than the one I have. But then what do they mean 4 quarts to all other applicable transmissions? Which transmissions do they mean?
Old Oct 6, 2008 | 12:29 AM
01quadcab's Avatar
I am not sure but it may be more than 1/2 at. I believe that the 4qts is for the 727 and 44? not sure though. but it's better than stock.
Old Oct 6, 2008 | 03:13 AM
LOGANSTANFORTH's Avatar
i got the pan with the cooling tubes in it from PATC tranmission......hold a few quarts over stock and is chrome and only 117 bucks......
Old Oct 6, 2008 | 01:56 PM
Yeah it's better than stock and it's only $20 plus $12 for shipping. Can't beat that. I've seen the one with the cooling tubes, pretty cool design.
