Weird Acting Duramax
Old Oct 2, 2008 | 03:45 PM
KiltEmWhooptem's Avatar
Default Weird Acting Duramax
I have a 2003 duramax i have a edge juice with attitude with level 6, AFE intake, 5 inch exaust.
I was going down the high way and the chip was on level 6. I floored it just to pass someone , it did fine for about 3 sec then it lost power, started doing this weird stuttery sound. it was almost like my stock tranny was skipping and couldnt get into the next gear,. then when i let off and drive normal it drives fine.
could anyone tell me why it is doing this and how to fix it.
Old Oct 2, 2008 | 03:47 PM
DangerousDuramax's Avatar
If you're on a stock tranny running the Edge on 6 you're going to not only going to limp it but you'll toast it pretty soon. Dont go anymore than 90hp over stock or you'll buying a new tranny soon. Did it lock into 3rd gear until you shut it off for 5 minutes?
Old Oct 2, 2008 | 03:52 PM
no i dont think its the transmission i sorta think its the fuel because it will black smoke straight till it sputters and it starts and stops and starts and stops black smokeing
Old Oct 2, 2008 | 04:01 PM
Sounds like you've got the proverbial Edge problem. Give them a call and see what new firmware they have out for your model. BTW- how many miles do you have on the current fuel filter?
Old Oct 6, 2008 | 11:03 PM
durallymax's Avatar
Sounds exactly like you edge is loosing communication.
Its common.
Take it out and send it in to Edge. If they cant fix it and your warrenty is up they will sell you a new one for $250.
If it is not the module you could be draining the fuel rail. This would cause the truck to basically stop then go again. Basically cutting in and out.
Doubt its the trans.
Limp Mode is not 3rd gear. It is considered 4th gear. The torque converter will also never lock up when in limp mode.
To override it dimply pull tot he side of the road, and cycle the key 3 times. This will get you home until you have time to clear the code.
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
blown502
Oct 18, 2014 03:14 AM
