Stock Duramax With Diablo
Old Sep 27, 2008 | 12:33 PM
kline17's Avatar
Default Stock Duramax With Diablo
hey does anybody know if it will hurt anything if i put a predator diablo on the 120 setting if i have all stock everything?... i have a 06 lly
Old Sep 27, 2008 | 01:07 PM
Oilfield_Mafia's Avatar
It CAN hurt your trans.. But lots of people run their programmers up hot like that untill they start slipping the trans. Transgo makes a kit to help hold extra power for ya, and its quite inexpensive. Its not a cureall, but it will help.
Alot of it depends on how you drive, and how the trans has been treated untill now.
I ran my 6spd allison HARD with my bullydog on the 120 setting for 30,000 + miles and only limped it once. Its all in how much you want to spend on it bud.
Old Sep 27, 2008 | 01:13 PM
2500HeavyDuty's Avatar
6 speed with a 120hp setting, give it like a few runs for it to learn and have fun. trans should hold it
Old Sep 27, 2008 | 01:38 PM
kline17's Avatar
what about if i just keep it on the 85 setting? would i be safer?....i really dont want to screw anything up and i dont want to spend to much money
Old Sep 27, 2008 | 01:45 PM
85 would be fine for daily driving, but the 6 speed trans are pretty stout if your curious turn it up and make like a 1/4, 1/2, 3/4 and full throttle runs and trans would be fine for weekend fun. for towing turn it back down
if it limps it locks the transmission in 4th gear and then u gotta reset it, and just turn the programmer down a little, or be more careful when hitting the 4-5 shift.
Old Sep 27, 2008 | 01:53 PM
kline17's Avatar
ok man thanks...sounds good
Old Sep 27, 2008 | 07:17 PM
delong_1's Avatar
id say get the $100 transgo jr. and youll be able to run the 120 tune w/o any problems
Old Sep 27, 2008 | 09:23 PM
WyoD-MAX's Avatar
i ran my banks six gun on my truck stock for a while i wouldnt run it for long periods of time it will shoot your egt's through the roof but for shorter periods it should be fine
Old Sep 28, 2008 | 08:50 PM
TCU Fan's Avatar
Aaron
You are going to limp the tranny of 120, I did it any times. Once you do it the first time it makes all the other times easier.
You have a 6 speed in your LLY?
Old Sep 28, 2008 | 09:00 PM
redneckbuckeye's Avatar
if you drive the truck hard you will be upgrading the trans, how long it will hold is any ones guess, if you want to play on the safe side run the 85 tune.
