Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
What's Everyone's Thoughts On These Rules?
Old Sep 27, 2008 | 12:10 PM
RSWORDS's Avatar
Default What's Everyone's Thoughts On These Rules?
The association I pull with does not have much of a diesel class... Right now it is your either in the 8050 mods or everything else. I'm trying to get the guy that runs it to step up next year and let us run for points. I want a set of rules that would allow everyone to run with out making it to broad of a range... Pretty much I have to put everyone into two classes... Full on puller or daily driver What I have done is taken the NADM 2.6 rules and modded the a little but. Our 8050 class is kinda like the 2.8 class. I'm looking to make rules for the "street diesel class" what y'all think of these? Are they fair?
8000lb Street Diesel
The Street Diesel (SD) class is designed for streetable pickup trucks with a wide variety of performance upgrades. Valid DOT registration and license plates are mandatory. The vehicle must be four-wheel drive.
Weight: 8000 lbs. Maximum, with driver.
REGULATIONS:
Trailering: Vehicles may be trailered to the track.
Ballast: Ballast is permitted. Hanging weights may not extend
more than 60 inches from the centerline of the front axle. No ballast may be added in the passenger compartment of vehicle. All ballast must be restrained to prevent movement.
Batteries: The batteries must be securely mounted. They may
not be located in the driver compartment or forward of the
radiator core support.
Body: The body must be an OEM truck body, including the full
bed floor. The body must retain full sheet metal. Metal aftermarket
hoods are permitted. Fiberglass is prohibited. The
hood must be closed and securely latched while the vehicle is
hooked to the sled.
Brakes: Four-wheel hydraulic brakes are mandatory.
Chassis: The OEM chassis is mandatory. The engine must be
in the OEM location for the body used. The vehicle must retain
the full OEM chassis. Wheel tubs, back-half conversions, tube
chassis, etc., are prohibited.
Cooling System: Radiators must be in the stock location and be
of at least stock size.
Credentials: All drivers must have a valid state drivers license.
Driveline: An OEM transmission and transfer case is
mandatory. They must have been an option on a one-ton or
smaller pickup.
Driver Restraint System: The OEM restraint system is
mandatory and must be worn.
Driveshaft Loops: All trucks must have at least six inch wide ujoint
shields around the rear u-joint constructed of at least 1/4
inch steel or 3/8 inch aluminum that will safely contain the ujoint
and the end of the rear shaft. All shields must be securely
mounted to the vehicle. Any front shaft u-joint that is visible
from the side of the truck must be shielded to contain the ujoint
and the end of the shaft. A new puller will be granted a
one-time waiver of this requirement.
Engine: The engine block must have been available as a
factory option on a one-ton or smaller pickup truck. Blocks
must circulate coolant freely. The use of concrete or other
block fillers is prohibited. All factory belt-driven accessories,
excluding the air conditioning compressor, must be retained
and powered via the crankshaft by a standard serpentine or ‘V’
belt. Electric fans are permitted.
Exhaust: The exhaust must exit rearward of the driver’s
compartment. Stacks exiting through the hood or fender-well
are prohibited. Two 3/8 inch diameter bolts must be placed
through the exhaust pipe in a cross pattern within one inch of
each other as close to the turbo as is practical. A new puller will be granted a
one-time waiver of the two 3/8 inch bolts requirement.
Fire Extinguisher System: A fire extinguisher system is
permitted. It must be securely mounted.
Firewall: The complete OEM firewall is mandatory.
Floor: The complete OEM floor pan is mandatory.
Fuel: The fuel must be pump #1/#2 diesel only. Soy/Bio-diesel
fuel is permitted. Off-road diesel fuel is prohibited.
Fuel Injection Pump: The fuel injection pump is limited to a
stock-appearing, OEM engine model-specific pump only.
The use of multiple high-pressure common-rail fuel pumps
is prohibited. Powerstroke engines with a single factory turbo
may utilize a second HPOP. Pumps from different years in the
same engine model may be interchanged. The P7100 injection pump, if equipped, must utilize a stock-appearing governor.
Fuel System: The OEM fuel tank is mandatory and must be
used. Racing fuel cells are prohibited and must be removed
from the vehicle.
Harmonic Balancer: All engines turning 4500 RPM and higher
must be equipped with a harmonic balancer or damper
meeting SFI Spec 18.1.
Hitch: The hitch must be a receiver-style hitch; reinforcements
are permitted. Reinforcements must not extend forward of
the centerline of the rear axle. Trick hitches are prohibited.
The hooking point must be the rear-most point on the vehicle (Excluding sled stops) and must be rearward of the stock location of the tailgate.
The hitch must be horizontal to the ground and stationary
in all directions. Bumpers may be notched or removed. The
hitch’s height from the ground may not exceed 26 inches. The
hooking point must have a minimum 3.00-inch inside diameter
opening for the sled hook. The hooking point will be measured
to the center of the clevis loop.
Interior: A complete interior, including dashboard, door panels,
headliner, etc., is mandatory. Two matching front seats are
mandatory. Aftermarket seats are permitted; they must be fully
upholstered. All factory controls (lights, signals, horn, windows,
wipers, etc.) must be retained and be operative.
Nitrous Oxide: Nitrous oxide is prohibited. No other oxygen
extenders are allowed. If vehicle is equipped with a Nitrous Oxide system the Bottle must be removed from the vehicle and the line to the injection nozzle must be removed and the nozzle capped off.
Propane: Propane is prohibited. If vehicle is equipped with a propane system the Bottle must be removed from the vehicle and the line to the injection nozzle must be removed and the nozzle capped off.
Rear End: Non-OEM rear-end housings are prohibited. The rear
end must have been an option on a one-ton or smaller pick up.
Rear axle bolts must be covered by a cap or shield.
Steering: The vehicle must retain the full, original OEM
steering gear. The vehicle must retain the original OEM power
assistance, if it was so equipped. Additional stabilizers are
permitted. Non-OEM power assist methods are prohibited.
Street Equipment: Complete headlight and taillight assemblies
(all) are mandatory and must be operative. Complete OEM
windshield and windows are mandatory. Windows must be
operative per factory specifications; that is, they must open
and close via OEM electrical or mechanical means.
Suspension
Front: The factory suspension configuration must
be retained. The upper mounting point for strut assemblies
must be in the factory location. Adjustable caster/camber
pillow ball mounts are permitted. The lower control arm
may be strengthened provided factory-mounting points to
chassis are maintained. The lower mounting point for the strut
assembly may be modified for improved caster or camber.
Strut tower braces, lower tie bars, sway bars, and limit straps
are permitted. Traction bars and devices are permitted. The
final decision rests with the Technical Department.
Rear: An OEM-style suspension is mandatory.
Traction bars and devices are permitted; they must be bolt-on
only; welds are permitted for attachment to frame or axle
housing. Control arms may be strengthened or replaced,
provided all original mounting points are retained. Strut tower
braces, lower tie bars, sway bars, limit straps, and camber kits
are permitted. The rear suspension must maintain a minimum
compression travel of one inch. All rear suspensions must use
at least one working shock absorber per wheel.
Tires: The tires must be DOT street tires. Cut tires are
prohibited.
Tow Vehicles: Towing vehicles to the starting line is prohibited.
Transfer Case: Non-OEM transfer cases are prohibited. It must
have been an option on a one-ton or smaller pick up truck.
Old Sep 27, 2008 | 12:11 PM
RSWORDS's Avatar
Transmission, Automatic: Non-OEM transmissions are
prohibited. Aftermarket torque converters, valve bodies and
internal components are permitted. Transmission brakes
are prohibited. Any non-OEM floor-mounted automatic
transmission shifter must be equipped with a spring-loaded
positive reverse lockout device to prevent the shifter from
accidentally being put into reverse gear. A functional neutral
safety switch is mandatory. All transmission lines must
be metallic or high-pressure-type hose. All vehicles with
engines running 4500 RPM or more and using an automatic
transmission must be equipped with a transmission shield
meeting SFI Spec 4.1 and must be labeled accordingly. A
blanket-type shield is permitted; it must be appropriately
labeled as meeting SFI Spec 4.1 and it must extend from the
rear of the block to the front of tail housing with a minimum
six-inch overlap where it is fastened. All non-blanket-type
shields must incorporate two (or one, per manufacturers
instructions) 3/4 inch by 1/8 inch straps that bolt to the shield
on each side and pass under the transmission pan unless
the transmission pan is labeled as meeting SFI Spec 4.1. All
vehicles with engines running 4500 RPM or more and using
an automatic transmission must be equipped with a flex plate
meeting SFI Spec 29.1 and be covered by a flex plate shield
meeting SFI Spec 30.1.
Transmission, Manual: Non-OEM transmissions are prohibited.
Aftermarket internal components are permitted. A clutch
meeting minimum SFI Spec 1.1 or 1.2 is mandatory on all
vehicles with engines running 4500 RPM or more. All manual
transmissions must be clutch assisted. Sequential shifters
are prohibited. All vehicles with engines running 4500 RPM
or more and equipped with a manual transmission must have
a flywheel shield labeled as meeting minimum SFI Spec 6.3
or greater. Applications for which an SFI Spec flywheel shield
is not available may use a properly attached SFI 4.1 or 4.2
blanket that completely covers the bellhousing; it must be
attached to the block and extend rearward to the transmission
with a minimum six inch overlap where it is fastened.
Turbocharger: The vehicle is limited to a single turbocharger;
the inducer bore on the compressor housing may be no larger
than 2.6 inches measured at the smallest diameter area of
the compressor wheel. The inlet will be measured using a
2.65-inch plug or internal calipers. A stock map width
enhancement (MWE) groove is allowed. No MWE groove will be
allowed that has a width greater than 1/4 inch. All provisions
allowing air to the wheel other than via the bore and the MWE
groove are prohibited. 6.4 liter Powerstroke engines may utilize the factory twin-turbo configuration.
Water Injection: Water injection is prohibited. All system
components must be removed from the truck.
Wheelbase: The vehicle must retain the original unaltered
factory wheelbase and track width. Front dual-wheel spacers
may be used only with accompanying positive-offset duallystyle
wheels.
Old Sep 27, 2008 | 12:17 PM
bigdaddydiesel's Avatar
THKS for the head ache!!!!
J/K that is a lot of information!!! Sounds good to me though,...but I am a nobody who does not pull like that...
1997silverado
Mar 12, 2015 07:40 PM
DetroitDiesel
Jan 29, 2015 08:13 AM
Nov 3, 2014 12:50 PM
ryanf
Oct 13, 2014 10:14 AM
