Seat Belt Won't Unlock????? HELP!!!!!
My seat belt in the seat is in a locked position and wont release. Is there a a way to unlock it or do I have to replace the seat belt assembly. Looking for anthing that will help. Thanks
ha! another person who suffers from the dodge seat belt design! In their infinite wisdom dodge used an electronic system to lock the seatbelt during a collision or pretty much any pothole. The system is constantly using power so to keep the batteries from running down there is a 30 minute timmer that starts after you shut the truck off. To send power to the system to unlock the belts you only need to open the door ... unless your door switch that kicks on the dome light is broken .. then open the passenger door.
Give that a try .. drove me crazy until I realized the belts unlocked after I opened the passenger door.
yep thats exactly what I'm talking about too. There is a controller under the drivers seat that releases the seat belt lock so you can pull it out and put it on. For some reason mine doesn't know that the engine is running so it wont unlock unless you open the door to reset the 30 min timer.
And if I'm completely wrong in understanding what you are talking about then ... Whitmore told me to say it and you know how crazy that guy is.
The part thats locked up is the actual shoulder belt it wont pull from the seat to lock it. Any ideas
i dont really know you might have to take the thing apart and it probably has like a broken spring or something up in there
