Somethings Tapping
Old Sep 22, 2008 | 11:37 AM
zjohnsonua's Avatar
Default Somethings Tapping
noticed it about a week ago and it hasn't gotten any better or worse. It's not as solid sounding as a knock but it seems to be more noticeable at higher rpms. that may just be because the engines quieter there though. My question is does this engine have solid or hydraulic lifters that could be causing this? How bout an injector being the culprit?
Old Sep 22, 2008 | 12:45 PM
bigdaddydiesel's Avatar
IDK, but BUMP!
Old Sep 22, 2008 | 01:05 PM
Johnny Cetane's Avatar
Solid lifters. Could be a lift pump on its way out.
Old Sep 22, 2008 | 01:49 PM
Whit's Avatar
Site Mascot
Run an overhead on it to rule out valve lash
10 intake and 20 exhaust
Old Sep 24, 2008 | 12:08 AM
zjohnsonua's Avatar
Well this sounds like some fun fun heading my way then. I'm guessing that's thousandths Whitmore?
Old Sep 24, 2008 | 01:11 AM
Yeah.
This might help out:
B Series Valve Adjustment
Old Sep 24, 2008 | 10:16 AM
zjohnsonua's Avatar
just curious but what interval does cummins recommend the valves be adjusted? The truck only has 230k on it.
Old Sep 24, 2008 | 10:20 AM
Whit's Avatar
Site Mascot
yer truck .......about every 30k
the 24 valvers every 100k
Old Sep 24, 2008 | 11:33 AM
Also theres some good maintenance info here:
Ram Diesel Problems
Old Sep 24, 2008 | 09:14 PM
prromine's Avatar
Possibly lift the pump. My 97 has 103,000 miles on it and it ticks.
I talked to a guy in Norht Vernon In. that worked for Cummins at the 5.9 plant in Walesburo, In. (all he does now is tune and rebuild the 5.9) and he said that the link in the lift pump will click/tick when it gets some wear. So no big deal, unless the noise drives you nuts and fuel pressure is ok.
Rchobbit
Apr 1, 2015 08:02 PM
elsbland
Mar 13, 2015 05:34 AM
somarillw
Dec 15, 2014 12:00 AM
