No Smoke
Old Sep 20, 2008 | 07:58 PM
outlaw1_gt's Avatar
Default No Smoke
hey i have a small problem.. i put a smoke switch in to see what it did it didnt do all that mch so i took it out.. now much truck doesnt smoke on level 3 like it used to.. no smoke at all.. why?? what do i do to fix it? seems to be rnning the same.. any suggestions?
Old Sep 20, 2008 | 08:20 PM
SOUTHERN GA SMOKE's Avatar
are you gettng any codes? may have damaged the map sensor, and you not reading correct pressure... check the wiring and the plug and see? is the truck running different?
Old Sep 21, 2008 | 03:43 PM
outlaw1_gt's Avatar
well update i went to autozone and had them plug in my truck and it threw a code p0237 low boost voltage. i had them erase it and all is good.
Old Sep 23, 2008 | 05:55 PM
outlaw1_gt's Avatar
so far everything is still well.. just wanna make sure that the smoke switch is what caused the p0237 code? feedback please
Old Sep 24, 2008 | 01:22 PM
dukeboy_318's Avatar
you probably did what i did, you connected the switch to the wrong black wire, try the other wire and see if that helps. mine did the exact same thing, threw a code and didnt smoke at all, switched the wires and bingo, it smokes like a mother F**** in neutral
Old Sep 26, 2008 | 04:13 PM
underpressure!'s Avatar
How do you hookup a smoke switch...and what is it do??? Just curious
mattshow123
14
Mar 12, 2018 01:41 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
