Idle Stalling
Old Sep 18, 2008 | 09:11 PM
cummers's Avatar
Default Idle Stalling
I've a little problem folks. 1. I'm new to Cummins coming from 7.3's and 6.9's, and know nothing about the 5.9 CRD. 2. (The problem) My newly acquired 2004.5 cummins will not idle in park without stalling within 30 seconds. Put it in gear and it won't stall, back to park and it stalls. Everything seems to be running well otherwise. Starts right up, won't stall while driving, at a stop light, lots of power, no hesitation, etc. WHAT"S WRONG. I've noticed 2 things though. It's giving me the P2509 code and the fuel filter is quite noisy (does it have a pump in it?). Is the truck stalling as a safety feature for low fuel pressure or something else.
Old Sep 20, 2008 | 12:41 AM
2500HeavyDuty's Avatar
P2509. CM/PCM Power Input Signal Intermittant.
Bad ground?
Old Sep 20, 2008 | 12:55 AM
stkdram55's Avatar
Sounds like to me the something with the Torque Converter not unlocking check where the PCM grounds at that might fix your problem if the Power Train Control Module isnt operating right its probably causing your stalling problem
Old Sep 20, 2008 | 11:41 PM
cummers's Avatar
Thanks for the reply's.
I don't think it is the TC. When I take it out of drive and into park all is normal, it waits 10-20 seconds then shuts down. After disconnecting the battery the P2509 code is still there but it didn't shut down in park this time. I should say shut down, not stall, it is more accurate of a description (just as if I turned the key off). Where is the PCM ground?
Old Nov 12, 2008 | 02:29 PM
Dragon Flow Diesel 128's Avatar
can you read fuel pressure it seems like it might be the fuel control actuator just put one on a 04 cummins last week it was idle stalling in park
MechanicalDiesel
Aug 11, 2015 08:14 PM
Andyhc1
Mar 16, 2015 12:00 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
