Something Gave
Old Sep 17, 2008 | 07:49 PM
wilke12V's Avatar
Exclamation Something Gave
well something gave in the drive system. on my way back from the gas station when i got out of the throttle it would kick, like a hard jurk. then turning to go down my street, i got out of the throttle and then i heard a really loud whine and grinding noise. i thew it in neautral it stoped, coasted it to my drive way, and now i put it in any gear and it makes the sound. revurse, drive, 1, 2, tried it iin 4hi 2hi 4lo and neautral. when i even put the tc in neautral and put the coloume into drive or revurse it still makes the noise. HELP ME
P.S. i dont have park now.
Old Sep 17, 2008 | 08:06 PM
wildbill's Avatar
No park means the pawl gave up. Something in the tail end of the transmission went and it took the pawl with it.
Old Sep 17, 2008 | 08:48 PM
Whit's Avatar
Site Mascot
input shaft would be my guess
Old Sep 18, 2008 | 08:30 PM
wilke12V's Avatar
im thinking that its the male end of the shaft. but more ideas would be grreat so i know what to look for
Old Sep 18, 2008 | 08:53 PM
Benjamin's Avatar
Bombardier
if it was the input shaft it would still have park. if you don't have park i'd put money on either the planetary gear set (the sun gear i think most people call it) or the output shaft. the parking gear is not really a gear but a lever that fits into a slot in the rearmost drum in the tranny that is connected to the output shaft.
Old Sep 19, 2008 | 08:17 AM
MotorOilMcCall's Avatar
I had a similar sound when my Transfer Case blew the planetaries... Except mines a stick. It actually siezed everything, I couldn't engage the clutch with it in gear or it would stall. Put the T-Case in nuetral and I could at least pull it back to my shop without the noise.
Not saying thats what it is, but check it. Throw the rear end on some jackstands, grab a stethoscope, put the truck in gear and crawl under. Put the scope on the tranny, the t-case, and anywhere else you hear noise... you'll find out real quick where its coming from.
Old Sep 23, 2008 | 12:01 AM
wilke12V's Avatar
well i looked at it today and i dont know what broke but i have a hole the size of a dime in my tc,i dont even want to know what broke, so my bet is i need to get a new one. thanks guys for your help.
Old Sep 23, 2008 | 06:23 AM
stkdram55's Avatar
I agree with the Parking pawl and the output shaft reply, you might also need to check the input hub on the transfer case, a friend of mine when he switched his from auto to stick...not saying that it is definately that but something else to look at
Old Sep 23, 2008 | 02:54 PM
wilke12V's Avatar
my dad looked up the # to the tc and said it was for a manual trany., i have an auto. does it matter?
Old Sep 23, 2008 | 03:09 PM
BigDiesel359's Avatar
the auto and manual transfer cases I think had different size input shafts if I'm not mistaken.....I know the 241 has smaller shafts than the later 271's, but I'm not 100% on manual -auto 241's like yours...sorry. best of luck
