Coolant Leak
Old Sep 17, 2008 | 02:20 PM
Dieseldog92's Avatar
Default Coolant Leak
I have a 92 1 ton and i have been having a coolant leak and can't seem to trace it to the problem. After sitting over night there is a small puddle under the truck and its not the radiator or the hoses. It drips down from above the ac compressor and the compressor is always wet. The truck is not running hot by any means but i live in oklahoma and it wont be too much longer before it gets cold and i will have to replace the water with antifreeze and that will become a more exspensive leak. any help?
Old Sep 17, 2008 | 03:17 PM
wildbill's Avatar
Water pump is in the vicinity. Sounds like it's time for a new one.
Old Sep 17, 2008 | 09:04 PM
welderboy250's Avatar
i know u said it isnt the hoses but u may wanna take another look cause the lower rad hose connects just above the AC pump. and above that is the thermostat housing, could be leakin there. other than that, like bill said, water pump. dont be alarmed. if u know how to properly operate a wrench u can change it and it should be less than a hundred bucks.
Old Sep 17, 2008 | 09:06 PM
Whit's Avatar
Site Mascot
I would bet water pump too............the fan will get hold of the glycol dripping and mover em around bad....hard tellin were it will drip from
Old Dec 14, 2008 | 12:02 PM
cummins by birth's Avatar
yea check all hoses good and water pump and all, if its just a small leak...get u a bottle of DIKE it wont stop anything up but it will find and seal small cracks every time, cracked heads, head gaskets, hoses, heater cores...the works
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
