Quick Question
Old Sep 16, 2008 | 03:34 PM
STROKER400's Avatar
Default Quick Question
I am reading alot on the boost foolers. Do i need this running the edge with attitude i never had any problems building ,pretty much 2 much boost well over 44 plus at times. what is the boost fooler do and for the money should i get it even though i think i am building full boost.
\maybe a stupid question but would like to know
Old Sep 16, 2008 | 05:52 PM
Cowbizzoy's Avatar
i kinda thought the edge had a bit of a built in boost fooler.....
Also not too sure if you really want to go above 44....w/o studs and such... esp a stock turbo
Old Sep 16, 2008 | 06:05 PM
wildbill's Avatar
The Edge Juice does boost fooling. But what a boost fooler does is trick the ECm from opening the waste gate until the fooler tells it to. Stock is 34 and it lets it run up to 42 for better performance. Keeps it from throwing an over boost code also.
Old Nov 14, 2008 | 09:45 AM
Dragon Flow Diesel 128's Avatar
boost fooler makes it blow black smoke
Old Nov 14, 2008 | 10:07 AM
madhat's Avatar
Yeah, the edge has built in boost fooling.
On that note, my edge never read true boost numbers until I had it updated. The new one did good.
Old Nov 14, 2008 | 02:21 PM
when I plug in my scanner reading boost with my smarty which has built in boost fooler as soon as i take of it automatically reads 45 psi of boost when really it takes about 2 or 3 seconds to get to full boost fooling the ecm into full fuel which creates black smoke
Old Nov 25, 2008 | 02:32 PM
STROKER400's Avatar
Thanks I thought the edge does boost fooling but i was not sure.
dutchsupreme
Diesel Engine Conversions
May 25, 2015 08:48 PM
May 8, 2015 11:10 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
12thman
Jan 20, 2015 03:22 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
