BHAF
Old Sep 15, 2008 | 02:17 PM
01quadcab's Avatar
Default BHAF
my dads 04 needs some air anyone have a write up or info on how to set it up on the 3rd gens as it's for sure not the same as a 2nd gen. Thanks. I signed him up on here but he is in alaska and cant ask questions lucky punk on a month and a half vacation.
Old Sep 15, 2008 | 04:33 PM
Johnny Cetane's Avatar
Do you want to go with a full intake or just kill the box and slap on a filter?
The filter part is easy. Remove the box and get a 4" PVC pipe about 4 inches long and use it to connect your stock air tube to the new filter. You'll want to make something to keep it from resting on the bottom of the air filter and a heat shield would help you out too.
Old Sep 15, 2008 | 10:24 PM
jonathanrayce's Avatar
Gut the torque tube at the same time.
Old Sep 16, 2008 | 01:16 AM
01quadcab's Avatar
was looking to do the box removal and add the filter. anyone have a template on makin a heat shield for these?
Old Sep 16, 2008 | 02:58 AM
stkdram55's Avatar
https://www.dieselbombers.com/24-val...at-shield.html
Here ya go its like the 3rd or 4th post down, thats for the 2nd gen but it might get ya the general idea
Old Sep 16, 2008 | 09:51 AM
Heath's Avatar
Authorized Amsoil Dealer
Got a filter to put on the tube...
EaAU 4510
This is a 4.5" flange like the stock. If you end up with a 4", there are other options listed there.
Can get you a price if you wish
Old Sep 16, 2008 | 10:21 AM
01quadcab's Avatar
thanks. so nobody out there has done this to a 3rd gen then?
EaAU 4510
I will be getting ahold of ya going to be needing some more tranny fluid as we ended up doing the trans in the motorhome before dad took off for alaska, so he used 5 gallons to fill the 400 a tranny cooler and a custom tank to add fluid to the system a buddy made for him. trans temp was getting 240 plus before we changed up and added the good stuff now it's been to 230 but that was pulling the grades from what I was told.
Old Sep 17, 2008 | 03:38 PM
I have seen it done plenty of times. It is very simple. No problem. I would gut the torque tube also.
Old Oct 29, 2008 | 06:18 PM
wyoranch's Avatar
Ive been wanting to do one on my '03 too. What about the air flow sensor thing thats on the factory box? How do you mount that when your putting on a BHAF? And does anyone have the filter number?
hoeky22
Jan 2, 2015 04:54 PM
