1-2 Shift Problem
Old Sep 14, 2008 | 05:39 AM
toddlaco's Avatar
Default 1-2 Shift Problem
Just wondering if there is a common problem that causes the transmission on a stock 2000 CTD with automatic trans to not shift from 1-2 properly?
The truck will go all the way to red line and not shift to 2nd gear unless I let off the accelerator. Just the slightest release of the accelerator will let it shift into second, but never until I let off slightly. Seems like something might simply be sticking. It shifts normally in all other gears, the problem only exists from 1 to 2. Otherwise the transmission works perfectly.
Thanks
Old Sep 14, 2008 | 10:00 PM
biged681985's Avatar
is this under hard acceleration, cuz mine is doin it uder hard acceleration now.
Old Sep 15, 2008 | 05:51 AM
toddlaco's Avatar
No. It does it under any type of acceleration, and it doesn't make any difference if I have the Edge unit set to Stock or Extreme.
Old Sep 18, 2008 | 07:23 AM
toddlaco's Avatar
Well, the truck is in the tranny shop. Full trans rebuild with all the good modifications and heavy duty torque converter.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
AKDodge
May 14, 2015 12:52 PM
