Rail Pressure Relief
Old Sep 9, 2008 | 07:31 PM
wildbill's Avatar
Default Rail Pressure Relief
Just curious, but will the engine still run with it leaking slightly or even fully blown?
Old Sep 9, 2008 | 08:20 PM
MRaynor's Avatar
Is yours leaking?
Old Sep 9, 2008 | 08:39 PM
wildbill's Avatar
IDK! I got a P0148-Hi Pressure Common Rail code a while back. Truck seems to run the same after wards.
Old Sep 9, 2008 | 08:48 PM
Red_Rattler's Avatar
High Tech Redneck
It'll run but it will be low on power
Old Sep 9, 2008 | 08:52 PM
wildbill's Avatar
How bout if it were a small leak? It runs good, I'm just speaking hypothetically.
Old Sep 9, 2008 | 10:46 PM
skynyrd's Avatar
bosch says that once they pop they will never totally seal again. i'm not really sure what pressure they pop off at but i know i ran mine above the limit and then i could hold only like 20k at wot no matter what i did. sometimes it would be hard to start and would kinda studder at idle. well mine is fixed i plugged the dang thing.
Old Sep 9, 2008 | 11:11 PM
DangerousDuramax's Avatar
Originally Posted by MRaynor
Is yours leaking?
Heeeeeeere's your sign.
Old Sep 10, 2008 | 11:12 AM
wildbill's Avatar
Reckon I'll do the rail cap on the morrow!!
Removed the banjo bolt and it's standing full of fuel. Believe it's leaking?
For shiz and giggles I called up for a price. $456.xx friggin dollars for the reliever!!!!
Old Sep 10, 2008 | 11:35 AM
skynyrd's Avatar
yeah that's the main reason that my banjo bolt got tapped and i installed a set screw in the banjo bolt. not leaking now. oh yeah had the set screw and tap in the garage so it didn't cost me a dime!
Old Sep 10, 2008 | 11:49 AM
wildbill's Avatar
Set screw? I was searching all over heck for a plug!!!!
