KDP repair kit
found this, im sure one of the venders here sells it also.
Dowel Pin Repair Kit for 94-98
You can probably do it for less than that - dont need a kit - you can make a tab yourself and get a longer bolt. Then pick up a new crank seal, and timing cover gasket from Cummins, or if your cheap just use some RTV instead of getting the gasket.
http://www.dodgeram.org/tech/dsl/Dowel_Pin/tab.htm
A couple of other things to know - make sure you get some red loctite (262) and loctite all the other bolts that are under the timing cover, and since the cover is off already, this is a very good opportunity to bump the timing (its probably slipped from the factory spec anyway)..
what factory parts i can use to get the most out of my 12v? i heard something like a bus pump and marine injectors?
if all goes well i will be picking up a 94 single cab 4x4 12v, i will need to fix the KDP, the owner said he hasnt fixed it.
You dont need a new injector pump the one on there will be just fine - with a few mods you can be 400+ hp. Yeah, you can pick up the 370 Marine injectors and they give a real nice bump in performance - but they arent the best option as they do not have the correct spray pattern, That being said, they do work just fine for a lot of people (especially if you can live with smoke and a little haze at idle).
Heres some info and p/n's if youre interested:
Killer Dowel Pin "tab- Fix -tips"
HELLO ALL....
I did my DOWEL PIN fix today,,,and come up with a few things that may help.
First of all I bought that gasket and seal an longer bolt through a CUMMINS shop.
GASKET==#3918673.....$21.88
SEAL==#3804899......... $29.88
BOLT== (8mm X1.25 X 25mm)====#3900631==== $1.11
This is about $30 cheaper then DODGE DEALER,,and gasket is ALOT BETTER then using R.T.V,,,(most people overkill when using it) They seem to use it as if they were SELLING it,,instead of buying it.
If using R.T.V.,,,A little is BETTER then alot,,,a small BEAD is best (an less of a mess) an you don't have to worry about it falling in to the oiling system.
This info comes from the manufacture,,as they came to my place of work and gave a SEMINAR on this topic.
"SHORT CUTS",,,,As I read, that DAMM washer tank IS a real pain..
So I just said lets try doing it with out taking the fan shroud off.
I DID cover the back of radiator,,(I already had my FAN OFF from freezing my BUTT OFF last winter) so that was a BIG HELP.
You can reach down over the fan shroud,,and go to town....
"MY PIN WAS A-OK",,, I made my TAB.... One thing that I NEVER READ was YOU CAN'T SEE THE darn place that little BUGGER IS,,,,
I used a MAKE-UP MIRROR.... worked like a CHARM...I made a paper TAB ,,first ,,Just to get a great fit....then made the METAL TAB.
Word of caution to those of you that HAVE NOT HEARD OF "MURPHY'S LAW"....IF there IS A HOLE to drop some thing in (near wear you're working,,YOU WILL DROP IT IN IT.
Point of interest,,,,put a RAG OVER your gears,,,,because there is a hole,,just under where the tab/bolt is ,,unless you have BETTER LUCK then I always do.
Again for those that have NEVER done much mechanic work,,,when you do your SEAL,,,, look over things GOOD,,make sure you know where you going,,,as this seal is EXPENSIVE,,,"AND DO USE THE SEAL SLEAVE" when putting the cover back on...(Advice here,,,, have a friend "HELP" Hold the darn cover.)
SORRY FOR THE LONG POST..
Hope it helps SOMEONE.
HELLO ALL....
, its going to live the rest of it life as a pulling truck so economy isnt on the list.
