Dually To Single Wheel Conversion
Old Sep 7, 2008 | 06:01 PM
sawmillman's Avatar
Default Dually To Single Wheel Conversion
how can I convert my dually to a single wheel? Is it just as easy as pulling the spacers off the front and buying a set of wheels or is there a little more involved in this?Thank for any help.
Old Sep 7, 2008 | 06:05 PM
Oilfield_Mafia's Avatar
I dont think there is anything to "Convert" so to speak.. Just get a set of wheels to fit it.. And yes, remove your spacer, and your fenders.. Unless of course you go to a super single
Old Sep 7, 2008 | 08:51 PM
gone ropin's Avatar
pull your front hub adaptors buy full set of rims and tires you will have a little longer rear lugs than others, and if you get rid of your rims and adaptors let me know i could use them
Old Sep 7, 2008 | 09:26 PM
slowtowpig's Avatar
to bad your not closer, my buddy is wanting to go from single to dual. yall could swap everything over.
Old Sep 8, 2008 | 09:29 PM
sawmillman's Avatar
I've been planning this for awhile just trying to talk the wife into a set of wheels other than stock.That front spacer looks like a real joy to take off and suggestions?
Old Sep 8, 2008 | 09:43 PM
gone ropin's Avatar
when i have to take mine off to turn the rotors i i put it on stands and use a pry bar stuck between the lugs w/ the handel hitting the ground, and a 7/8in end wrench and a brass hammer, works for puttin them on as well
Old Sep 28, 2008 | 09:12 PM
Beatty97's Avatar
soakem down with pb blaster for a week or so thats what i did and mine came right off
Old Oct 23, 2008 | 02:03 PM
badfxsy07's Avatar
Default 1997 Ram 3500 rear single conversion
Does anyone know if the rear ends on the 2500 and the 3500 are the same width???
I want to do the single rear conversion as well, but the cost of a new bed and axle might change my mind.
Thanks
Old Oct 23, 2008 | 02:48 PM
xzaq103's Avatar
FormerVendor
You could always go with a flatbed and sigle wheel. I wanted to do this back in 05 with my 3500 but didnt i cant remember the reason but im thinking it was because of the rear axle being to wide or maybe to narrow. Ill see if i can find my old posts.
Ward_59
May 12, 2015 04:39 AM
Brokencummins
13
Apr 20, 2015 01:05 PM
6.5dieselman
Feb 26, 2015 04:45 PM
CGwill
Jan 26, 2015 02:10 AM
2002cabandchassis
Oct 29, 2014 01:59 PM
