RPM's @ 100KM or 60MPH?
Old Sep 7, 2008 | 01:12 AM
timberfalls's Avatar
Question RPM's @ 100KM or 60MPH?
I have a 1990 2500 with the 5spd, standard tires,no guages though and I wanna know what my rpms are at 100kms in 5th gear ?
Old Sep 7, 2008 | 09:54 AM
W150CTDproject's Avatar
i have the same. 1990 CTD 250 with a Getrag 5 speed and 235 tires, 2WD though. It depends on rear end gear ratio. My truck wide open and fueled out @ 2500 rpm with stock spring (and with pump turned up) is 75-80 mph. So my guess is with my truck 1800-2100 rpm @ 60 mph, but im not sure. I have a tach on the way.
Old Sep 7, 2008 | 10:39 AM
rubberfish's Avatar
If you can tell us what gears you have,
there's a formula that you can use to tell
what rpm's your running.
Old Sep 8, 2008 | 10:24 AM
C/PRD/'s Avatar
Definatley need to know your rear ratio to tell.
Old Sep 9, 2008 | 12:54 PM
I'l check the VIN and find out gears thanks
Old Sep 9, 2008 | 12:58 PM
Johnny Cetane's Avatar
Take a look at the rear axle. There should be a tag on one of the rear cover bolts telling you what gears you have unless it has disintegrated.
Old Sep 9, 2008 | 11:34 PM
2500HeavyDuty's Avatar
https://www.dieselbombers.com/calculators.php
Old Sep 18, 2008 | 05:02 PM
Question RPM's at speed
I have getrag 5spd, 3:55 gears and 265/75/16's I don't know the formula but...
You can do it!!!!
Old Sep 18, 2008 | 05:10 PM
whats the gear ratio for the 5th gear
if its 1:1 the speed should be:
2000rpm = 50.4mph
2500rpm = 63.0mph
3000rpm = 75.6mph
3500rpm = 88.2mph
Old Sep 18, 2008 | 05:11 PM
THANKYOU 2500HD for that calculator I couldn't find her for fools gold when I searched
