Transfer Case?
Old Sep 3, 2008 | 07:20 PM
Duramax03's Avatar
Default Transfer Case?
i just took in my truck to the dealer and they said the pump wasnt working 4 a while so it trashed the transfer case...and they said $1400 for a new one.
Where can i find a rebuilt or used one? any suggestions?
Old Sep 3, 2008 | 11:07 PM
2500HeavyDuty's Avatar
did it get pump rubbed?
Old Sep 4, 2008 | 07:20 AM
Jazz's Avatar
Pump rubbed? Can you explain this to me a little more
Old Sep 4, 2008 | 09:59 AM
Rttoys's Avatar
Simple, the oil pump in the t-case mates to the rear cover. There is a retaining clip that is suppose to help take out any slack in the oil pump mounting area, the pump will actually move just enough to rub right through the clip. Once the clip is rubbed through it begins to rub through the rear case. You will get a small hole on the outside of the case and you will loose all of your t-case fluid. It usually only takes a few hundred miles to completely empty the t-case and run it dry, causing a lot of damage. Some are lucky enough to spot the leak early and fix the problem, some are not so lucky and will have to replace the entire case.
Old Sep 4, 2008 | 10:44 AM
there are fixes for this too, Mike L and Eric Merchant make them, but it involves removed the transfer case and taking the back cover off to replace one part with a better one and putting it all back together.
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
miked2805
Oct 19, 2014 11:02 PM
steves2500diesel
Oct 14, 2014 05:36 PM
