Missing
Old Sep 3, 2008 | 07:59 AM
89silverbullet's Avatar
Default Missing
I will be at a idle with a bad shake. i accelerate and it sounds like half a cummins is running until 20 mph. after that it runs pretty good. Is somthing on its way out or do i have a sticky injector? help its a every day driver any input is great.
Old Sep 3, 2008 | 06:55 PM
RSWORDS's Avatar
Yuo have gauges? What do they say?
Lets start with teh simple stuff... Check for fuel leaks in the system. When is the last time you changed your fuel filter? Is it old fuel in the truck? I would run some Power Service or something along those lines in a tank or two. Go ahed and double the amount they recommend. could be an injector.
Old Sep 3, 2008 | 08:17 PM
stkdram55's Avatar
Old Sep 3, 2008 | 08:48 PM
gone ropin's Avatar
try bleading your injector lines at the pump and then at te injectors, with the truck running, this will also let you know witch injector is not working rite,by the sound of your engine,and this is good practice to do a few miles after you change your fuel filter to be shure to get all the air out of your system,
Old Sep 3, 2008 | 09:44 PM
RSWORDS's Avatar
If you prime the filter with the lever on the lift pump before you start the truck you should not have to do this. Bleeding the lines is a band-aid fix for a leak. Remeber... A leak can go either way... seeping fuel or sucking air.
Old Sep 5, 2008 | 07:58 AM
it is running like hell. I have ran some injector cleaner through it. next is getting a fuel filter from san antonio or midland odessa. im in the middle of them.
caffeyonthebeach
99-03 7.3L Performance
Jan 21, 2016 07:36 PM
Sep 30, 2015 12:40 AM
dawnrogerl
Jan 21, 2015 09:10 AM
jrsavoie
Shade Tree , Pro-Mechanics & Fabrication
Nov 25, 2014 09:48 AM
Stick_Welder
9
Oct 24, 2014 04:10 AM
