Speedometer Quit
Old Sep 2, 2008 | 12:44 PM
Jazz's Avatar
Default Speedometer Quit
My speedometer has just quit on me the last 2 days and then starts working again. It's done this twice. last night on the way home from the lake it quit on me then started working after about 5mins. and worked all the way home. Today when I left the house no speedometer again then it started working. Just got home again and everything is working fine. Any ideas?
Old Sep 2, 2008 | 01:51 PM
2001shrtbedcummins's Avatar
When it does it check the cruise control. Most likely the VSS (vehicle speed sensor) should be on the transfer case.
Old Sep 2, 2008 | 01:54 PM
Jazz's Avatar
Thanks Bud. I will give that a try
Old Sep 2, 2008 | 02:27 PM
No problem man, if the Cruise Control doesn't work then most likely the VSS.
Old Sep 2, 2008 | 04:55 PM
Red_Rattler's Avatar
High Tech Redneck
Just the speedo or all of the gauges? MY 2000 gave me a heck of a fight when the gauges stopped working! I'll let ya reply b4 I go into it any deeper
Old Sep 2, 2008 | 05:16 PM
Jazz's Avatar
just the speedo. just sat at 0
Old Sep 2, 2008 | 05:35 PM
stkdram55's Avatar
definately would say the VSS, mine went out and my abs and brake light would stay on but that is because my VSS in the rear pumpkin (i dont know why) so if it is just the speedo just change VSS and be done with it.
Man thats alot of VSS in one post
Old Sep 2, 2008 | 05:52 PM
yea they went to the transfer case/tranny in 2000 I think.
Old Sep 2, 2008 | 08:52 PM
bigb82789's Avatar
98-02 went in the rear end..
Old Oct 16, 2008 | 10:18 PM
Renteria1217's Avatar
I agree, it's the VSS. Mine was doing the same thing, sometimes it would work fine, other times it wouldn't. It ended up being the wire going to my VSS was all chewed up. I didn't even have to spend any money this time. So check the wire before you buy a new speed sensor. You could get lucky.
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
Powerstroke36
Sep 21, 2015 08:32 PM
Big Mike 62
Aug 27, 2015 08:29 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
