Exhaust Manifold Port Temps
Old Sep 1, 2008 | 07:16 PM
dalton06's Avatar
Default Exhaust Manifold Port Temps
I thought I read somewhere that if you get one of the laser temp readers and check the temp coming out of each exhaust and one is different that the others there might be an injector issue??? Will it tell me anything getting the temps if each port? I'm gonna borrow a laser from work Wednesday and see what each is... Thoughts?
Old Sep 1, 2008 | 07:48 PM
wildbill's Avatar
Isn't the most accurate test, but it helps troubleshoot which injector may be going.
Old Sep 1, 2008 | 07:50 PM
stkdram55's Avatar
yeah thats a decent way to tell if ya got a missin cylinder, some old timer told me to start it up and just touch the manifold of course he said you had to do this quick or you will burn yourself.
Old Sep 1, 2008 | 08:05 PM
dalton06's Avatar
cool. Just making sure it might tell me something. Thanks again
Old Sep 1, 2008 | 08:06 PM
stkdram55's Avatar
Old Sep 1, 2008 | 09:16 PM
Whit's Avatar
Site Mascot
let the motor cool over night then start it up and point the temp gun right at the exhaust manifold where it bolts up to each port......................rotate around doing this 4-5 times and the injector that aint workin wont make no temp
I did this on a Ford 6.0 and was dead on , he took it to the dealer and they said the same thing .....he had 2 dead ones
Old Sep 1, 2008 | 09:17 PM
mysterync's Avatar
Very common way for checking. you shouldnt see over a 40 Deg Variance, Just make sure you hold the Pyro at about the same distance!
Old Sep 1, 2008 | 10:00 PM
dalton06's Avatar
thanks for the info. Maybe I can get the truck well soon again.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
