Pullin Power
Old Aug 31, 2008 | 07:46 PM
welderboy250's Avatar
Default Pullin Power
is it reasonably possible to make 800 horse power with a ve? im guessing not but need some input. would it be more cost effective to use 1 or 2 turbos to get there? i think 80-90 psi is the pressure needed but i could be all wrong on that too.
Old Aug 31, 2008 | 08:42 PM
2001shrtbedcummins's Avatar
the VE physically cannot pump enough fuel for much over 500 hp...at that you're really pushing it. If you want 800 hp, swap on a shop built and flowed p-pump
Old Aug 31, 2008 | 09:21 PM
SINGLESTACK's Avatar
Thats not true you can put a whole lot of nitrous on it
Old Aug 31, 2008 | 09:35 PM
not even 14mm head? how bout the turbos?
Old Aug 31, 2008 | 10:43 PM
mysterync's Avatar
Yea just ask bobby!
Old Aug 31, 2008 | 11:32 PM
2500HeavyDuty's Avatar
80-90 psi would be hard to achieve if you cant make the fuel needed to make that kind of drive, you can juice it.
what have you done to your pump so far
Old Sep 1, 2008 | 06:27 AM
actually the truck dont even have a pump on it right now cause i had to borrow it to replace the ailing one one my other truck... but its supposed to have a ve. fuel screw turned to runaway and backed up slightly, aneroid pin ground, clocked, and installed with no plastic spacer at the top, star wheel turned the whole way down, top removed and aneroid arm ground about a 16th". the timing is still set stock cause i dont know how far to change it... on this truck with stock injectors and hx40 i get 35-38 psi. is the head and pistons the same for a first and second gen? how bout the cam? i like first gens and theyre cheap thats y im startin with one.
Old Sep 1, 2008 | 07:01 AM
stkdram55's Avatar
there was a guy down at scheids on the dyno that hit over 500 hp with his first gen, no spray either.
Old Sep 1, 2008 | 07:34 AM
yea, there's a guy on here I believe goes by the title KTACUMMINS that has gone I think a little over five maybe into the sixes. But I'm telling ya, it can't do it. Nitrous is no good if you're already burning all the fuel you have.
Old Sep 1, 2008 | 09:41 AM
RSWORDS's Avatar
KTA has teh current fuel only record from a VE (with a special built 14mm head) Here is his Info
KTA 627rwhp 1300tq b-1/hx-60 twins, KTA 14mm custom pump with aeromotive a-1000 fuel system and 1/2 lines and in tank pickup, buddha power EDM injectors, ATS exhaust manifold, 5" muffled exhaust, fleetguard paper air filter, custom cylinder head work
KTA 486rwhp 1200 torque same as above less custom 14mm pump
KTA 481rwhp 1081 torque same as above except B-1 only no twins
Everyone is saying that if he would spray it he could get close to 1000hp... I dunno. He has ALOT of time and $$$ in that truck. There is also alot done to it that he wont say.
It can and will be done... Will you be the 1st?
