Cummins QSB 5.9
Old Aug 30, 2008 | 02:37 PM
kevkuck's Avatar
Default Cummins QSB 5.9
I am attending a diesel school in Elko, Nevada and i am working on a cummins qsb 5.9 with a vp 30 injection pump. it is a 2005 but it has a 12 valve head. i was wondering if anyone knew of any cheap easy tweaks to get more power out of one. i am thnking of putting twins on it after i get it all put back together.
Old Aug 30, 2008 | 09:02 PM
Whit's Avatar
Site Mascot
a 2005 with a 12 valve head????
Old Aug 30, 2008 | 09:08 PM
Red_Rattler's Avatar
High Tech Redneck
Industrial application I take it then?
Old Aug 31, 2008 | 01:10 AM
gone ropin's Avatar
if this is an industrial block it will be about 60 to 70 pounds heavier due to it having more metal in it, and this makes it ideal for a hot rod engine and should hold up well
these blocks are sometimes refered to as encore blocks
Old Aug 31, 2008 | 02:03 AM
High Tech Redneck
A QSB engine is for industrial apps... Are you sure its a 2005 model? Because they had common rail injection 24 valves.... The 2005 Qsb is rated from 175hp-275hp depending on model I believe.
BTW Just thought of this, is it a front gear case or rear? Rear is useless to you which I'm sure you know, but just covering the bases.
Last edited by Red_Rattler; Aug 31, 2008 at 02:03 AM. Reason: Automerged Doublepost
Old Aug 31, 2008 | 04:52 AM
stkdram55's Avatar
im guessing this is the same engine we have in the yard dog at work, ours is i believe a 2003 with the 12v head but it has what i thought was a vp44 IP, but it could be the vp30 this guy is refering to. I would swap that electonic crap for a p-pump.
Old Sep 10, 2008 | 12:51 PM
kevkuck's Avatar
im positive its a 2005 cummins with a 12 valve head. it is an engine for industrial applications. they make a qsb 5.9 with a vp44 and i am pretty sure that it has a 24 v head, but we didnt get one of those.
nathanmueller
Diesel Engine Conversions
Sep 8, 2015 03:30 PM
plumberjack
29
Mar 3, 2015 11:38 PM
dezeldoc
For Sale
Feb 2, 2015 04:21 PM
cumminsaddict199
Dec 22, 2014 09:57 PM
Dan7769
22
Nov 6, 2014 03:05 PM
