DTC Question
Old Aug 28, 2008 | 09:07 AM
Cavalier's Avatar
Default DTC Question
I cleared my DTCs to install my performance chip and found these codes to clear:
P0302, P0540, P1093 & U1000.
Can anybody give some clues about these codes?
Thanks.
Old Aug 28, 2008 | 09:13 AM
bigdaddydiesel's Avatar
P0302=Fault Cylinder B-Misfire Detected (CYL2)
P0540=Manifold Intake Air Heater Circ
P1093= ??? you mean P0093?? it is; Fuel Sys Leak Detected-Large Leak
U100= Lost Comm With ECM/PCM A
Not all codes shown apply to every vehicle model.
P Codes shown with a � symbol may cause a dashboard indicator lamp to light.
Many logged codes are transitory in nature and are automatically reset.
Codes shown below are for GM vehicles only.
DTC P1000 is an indication that the vehicle needs to be driven for a period so that the vehicle can learn certain operating characteristics. This code cannot be cleared using the DTC Reader clear function.
Hope this helps...
Old Aug 28, 2008 | 09:18 AM
Jazz's Avatar
For future reference you can type in your codes here Diesel Bombers to find them At the top left where it says Bombsite go to drop down menu,tools, OBD codes. Hope this helps
Old Aug 28, 2008 | 09:20 AM
yeah is should, I did not know that either...
Old Aug 28, 2008 | 09:48 AM
Johnny Cetane's Avatar
I hate to ring the fire alarm but P0302 and the P1093 could be related. The relation would be a severely leaking injector. Have yours ever been done? One easy way to check is to check your oil. If it's overly full or stinks like diesel fuel then you know something isn't right.
Are you running an aggressive tuner? A P1093 means low rail pressure and an aggressive tuner will allow more fuel than the stock system can supply thus giving you the code. I imagine that it could also get you a random misfire code but I don't know how often you get this code.
The U1000 is a generic loss of comm code for the PCM. I saw a lot of these and they were just phantom codes. Erase it and see if it comes back.
Don't know about the other one. Have to do some checking.
Welcome to DB. Fill out your sig so we know everything about your truck. Stop by the Initiation section and tell us a bit about yourself too.
Old Aug 28, 2008 | 09:55 AM
2500HeavyDuty's Avatar
Welcome to DB.
Old Aug 28, 2008 | 01:17 PM
Cavalier's Avatar
Default Thanks
Thanks Guys for the input. I kinda figured there was a better place for me to go with the codes, but couldn't readily find it.
Anyway, my GMC has been running great with no signs of any problems. No, the injectors have not been touched. I did check the oil to make sure no problem there.
Thanks..............
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
