Chinese Heads?????
Old Aug 27, 2008 | 08:26 AM
Diesel Nut's Avatar
Exclamation Chinese Heads?????
Anyone ever pull the head off and find MADE IN CHINA in the casting????
We are having a battle with one of our vendors over a head that was supposed to be port/polished on the exhaust side and then shipped to the customer. Well, its been on the truck about 6-8 months and he stripped out 2 of the rocker arm bolt in the head. So, he pulled the head and found MADE IN CHINA in the casting.
Basically, The customer and I are in the position to say that Cummins DID NOT use Chinese heads on North American motors. Anyone know otherwise?
The Vendor claims to have pulled the head off a 99 2500. Now, he also claims there were some issues with the head and he had to send it to another machine shop. The customer mentioned when he received the head that the Port/Polish work looked a little shotty. I think a switch was made at the other machine shop myself, but will never be able to prove that. I really just need to know if anyone else has ever heard of a Cummins with the original head having a China stamp on it.
Old Aug 27, 2008 | 08:31 AM
stkdram55's Avatar
No never seen or heard of this and with all the people rippin there heads off or blowing them off (RSwords, Ben, ICsmoke) i would think someone of noticed this. So i would agree that a switch was made.
Old Aug 27, 2008 | 08:45 AM
Forrest Nearing's Avatar
I think most of the 5.9 heads are cast in Brazil. There are a lot of chinese heads out there, but I don't think they're OEM. I would send an email to Cummins
Old Aug 27, 2008 | 09:28 AM
Diesel Nut's Avatar
The customer works for Cummins, so we do have that inside info, and he is researching it more. I am just trying to find out if anyone else has ever seen or heard of this.
I am trying to work with the vendor to fix this, but he does not seem too interested. I just want to make sure that there is no way I could be wrong and maybe Cummins ran short and had to order heads from their China foundry.
Old Aug 27, 2008 | 01:56 PM
scottsjeeprolet's Avatar
Go RAVENS!!!!!!!!!
Might want to check the casting number and see if it match's any of the OEM heads you have around. Cummins should be able to look up that number and see if it's theirs.
Old Aug 27, 2008 | 02:01 PM
bigdaddydiesel's Avatar
Old Aug 27, 2008 | 08:56 PM
why is it backwards? you sure that isn't a marking on the deck left from the gasket?
Old Aug 27, 2008 | 09:00 PM
Benjamin's Avatar
Bombardier
That's a good question Forrest..... it kind of looks like that to me too....
um.... i'm on the stock head and original head gasket and head bolts thank you very much.....
Old Aug 27, 2008 | 11:32 PM
stkdram55's Avatar
Well i figured with all that NOS talk it might of went
Old Aug 30, 2008 | 02:46 PM
turbomar's Avatar
Exclamation gasket print
Yeah, that mark is the print left from the head gasket. It'l buff right out!
