Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
Review Of The JD 2305 With Pics
Old Aug 24, 2008 | 07:21 PM
MRaynor's Avatar
Default Review Of The JD 2305 With Pics
Before I get started, this is not to start tractor wars, it is for info purposes only and this is only my opinion of the tractor I was using.
The motor on my garden tractor took a serious dump and grass was getting tall and I have around 11 acres to cut. I started looking around for something to rent and this is what I found.
It has a 23hp Yanmar with a 54in deck, and it was 4X4. When I picked it up, it only had 5 hours on it.
I am very thankfull for the 4X4. We had had a lot of rain and some of the spots I had to cut still had water standing and was like a swamp. The little JD went through tough grass and weeds like you wouldn't believe even with the standing water.
It came equiped with anything that you would possibly need to set the tractor up the way you wanted.
It already had the connections for a front end loader.
It had a weight bar and all the weights that you would need if you were using it with rear attachments. There were five weights and each one was 50lbs.
On the deck there was a hook up for a water hose to rinse the underside after use. My personal opinion is that it didn't really work very well.
It even had an option to run both the under carriage PTO and the rear PTO at the same time. Not sure what you would use them both for at the same time, but the option is there.
The hydrostatic trans was very nice. You could easily fly over the not so tough stuff and go slower over the nasty stuff without stopping. That is a big thumbs up in my book.
In two days, I logged a full 20 hours on this tractor and loved it. It did a great job and as equipped can be bought for around 12k., or add a front loader and the price goes up to around 14k.
Like I said these are just my opinions and what I experienced. Hopefully it will help someone that maybe looking to buy a tractor like this.
Old Aug 24, 2008 | 07:25 PM
Redpatcher0481's Avatar
Nice tractor there Yeah that hydrostatic trans is nice.
Old Aug 24, 2008 | 07:56 PM
Woody35's Avatar
the engine must be pretty powerful if it needs weights on the front of it. let me know how that cleaner for the underside of the mower is. i have a Zero Radius Turn Bobcat that get so much crap on the bottom when it is wet so its a pain to clean it all up.
Old Aug 24, 2008 | 08:13 PM
Lucas Amick's Avatar
that's cool buddy can i borrow it?
have you gotten the other one back yet with the new motor?
MRaynor's Avatar
I only rented it, but the deck cleaner sucked. I didn't see where it was a benefit at all on this tractor. The water barely even ran out of it.
Old Aug 24, 2008 | 08:33 PM
Benjamin's Avatar
Bombardier
my granparents have always had JD lawnmowers. i love them.
i can see this being beneficial using an offset mower out the back to cut a larger path.... or for using a vacuum or motorized rake.....
good review mike..... would have been better if you took the weights off the front and showed us some wheelies on it......
Old Aug 24, 2008 | 08:50 PM
Woody35's Avatar
well do what i do and get your butt underneath and clean it. its not fun but it helps a lot.
Old Aug 24, 2008 | 09:04 PM
MRaynor's Avatar
I do that with my Craftsman garden trator. When I bought it, it had a 22hp motor but it now has a 26hp. You are right it is a major pain in the well you know, but I do it.
Old Aug 24, 2008 | 09:06 PM
MRaynor's Avatar
Thanks man. Truth be known, I think if that baby had a clutch it would have done wheelies even with the weights.
Old Aug 24, 2008 | 09:28 PM
2001shrtbedcummins's Avatar
Take it to the tractor pulls and run it on the small sled...
