Front Suspension Crisis
Old Aug 21, 2008 | 01:17 PM
Dieseldog92's Avatar
Default Front Suspension Crisis
For about a month or so my 92 d-350 has been leaning quite a bit on the front drivers side. Causing significant tire wear on the inside and a rougher ride than usual. While changing the tire i found the shock was blown and replaced that. Then i find the real problem. Where the bolt connects to swing arm where the bushings go is completely broken through. I mean it broke through the bushing and is now tearing into the actual swing arm. I'm no suspension expert. Does anyone know where i can get a new one and if it could be done in the driveway?
Old Aug 21, 2008 | 01:35 PM
LOGANSTANFORTH's Avatar
if you need a new control arm you might as well head to the junk yard or local crash parts dealer.......i got a post somewhere on here of all the parts numbers that you will need.......
Old Sep 18, 2008 | 09:09 PM
dpuckett's Avatar
It CAN be done in the driveway. Is it the upper or lower arm? I have some spare lowers. Dont have the uppers (thank you, USPS )
Daniel
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
carid
Apr 22, 2015 09:28 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
