Smoke Button Help...(attn. cumminsdieselboy)
hey since im a newbie and i cant send PMs till i post 10 times i figured id just post my question. btw if you read this cody, this is chuck who bought your red truck. my question is, and im sure theres a thread on here that i just couldnt find, i should have my twins setup here by fridayish and i want to rig up a smoke button off of the BOV. do i need any special BOV or will any one work and what all do i need to do? thanks-chuck
nice to see you made it.
how i did mine was i got a BD turboguard which has an electric solenoid to hold boost to the top of the valve. when actuated it releases pressure in intake tube and thus blows off. it also comes with a controller that uses the voltage from the tps to blow it off automatically when a set amount of voltage is lost.
I hooked a 12v power wire from a momentary switch with a 5amp fuse hooked to the power wire to the solenoid.
when one pushes the button, the truck will build no more than 5lbs of boost no matter what you do
. works good, things can get hot quick,
so watch EGT's.
Let me know of anything else i can help ya with.
Cody
how i did mine was i got a BD turboguard which has an electric solenoid to hold boost to the top of the valve. when actuated it releases pressure in intake tube and thus blows off. it also comes with a controller that uses the voltage from the tps to blow it off automatically when a set amount of voltage is lost.I hooked a 12v power wire from a momentary switch with a 5amp fuse hooked to the power wire to the solenoid.
so watch EGT's.Let me know of anything else i can help ya with.
Cody
Chuck, Enjoy the site...
