need more fuel?
Old Aug 16, 2008 | 09:20 PM
dalton06's Avatar
Default need more fuel?
is there a way to tell if you need more fuel?
Old Aug 16, 2008 | 09:28 PM
2500HeavyDuty's Avatar
When the Needle is pointing at "E"
Old Aug 16, 2008 | 09:32 PM
wildbill's Avatar
When you get on going down the road, and it starts to buck, need a little bigger lift pump.
Old Aug 16, 2008 | 09:38 PM
dalton06's Avatar
mine does the bucking thing, but I thought that was the trans slipping? Will my aux. lift pump not help any?
Old Aug 16, 2008 | 09:45 PM
wildbill's Avatar
The only way it will help is if the factory pump is in good shape. If it starts to fail, any aftermarket will be useless, and your sittimg on the side of the road. Factory pump won't allow suction, so the only way is to bypass it completely is w/ a FASS or AD pump.
Old Aug 16, 2008 | 09:53 PM
whats your RP and how much fuel/timing r u adding
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
Gm3500
May 7, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
