No 4WD
Old Aug 16, 2008 | 06:06 PM
Cumminscowboy_101's Avatar
Default No 4WD
OK so the wife has recently informed me that the 4 WD in the Dodge has gone out. I kind of saw it coming, when I left for Iraq almost a year ago, I only had 4 Low. So now I have none. My question: Can it be anything other than the transfer case itself? (It's not the linkage, she checked) If it is the transfer case, how hard a job is that to do on this truck? I'm thinking not to bad....
Old Aug 16, 2008 | 06:27 PM
wildbill's Avatar
Sounds like it needs remand. Going to have to have a 4x4 shop do it, and it's going to be around $700-$1000. 2 drivelines, a few bolts, a linkage, and a couple electrical connections. Should only take about an hour, not real hard at all.
Old Aug 16, 2008 | 07:17 PM
youngcummins's Avatar
i think there are some vacume lines on the axle check those my 2cents
Old Aug 16, 2008 | 08:23 PM
stelldo's Avatar
i agree try simple?cheap stuff first
simple/cheap
Old Aug 16, 2008 | 08:40 PM
Uncle Bubba's Avatar
The simple things are the two vacuum lines on the front of the transfer case and the adjustment of the shift lever itself. After that is the front axle disconnect that is a common problem best solved by installing a manual disconnect available on the aftermarket. If that doesn't fix it then look at the transfer case. Might be something as simple as low fluid levels in the front axle or transfer case.
Old Sep 3, 2008 | 06:19 AM
Thanks I go on leave in 3 weeks I'll check it out.
Old Sep 3, 2008 | 06:25 AM
stkdram55's Avatar
yeah check the vacuum lines going from the Transfer case going to the front axle and the thing(i cant think of the real name) they hook into sittin on top of the axle on the passenger side of the axle.
Old Oct 7, 2008 | 10:50 PM
jordan henne's Avatar
it could be your transfer case. if you have an auto locking axle there is a small sleve that slides inside in every now and then mine will get jared in there and i dont 4 wheel drive
Old Oct 7, 2008 | 11:02 PM
94cummins12v's Avatar
there is a selector switch on the top of the transfer case for the vacuum lines thats what casued my 4x4 not to work when i bought my truck
Old Oct 12, 2008 | 07:18 PM
akdiesel97's Avatar
My problem was the Vacume lines some snow/ice chunks got knocked up under there and hit them off. Theres nothing really holding them on there to well. I had some ice actually inside the vacume line after and we had to bring a hair dryer and suck the lines out before i could use the 4x4 again.
