Gov Spring Numbers
Old Aug 13, 2008 | 11:27 PM
welderboy250's Avatar
Default Gov Spring Numbers
i took the top off an old ve i had layin in the shop and the gov spring had a 386 on it. i think the 3200 spring is 366 but what is 386?
Old Aug 14, 2008 | 05:47 AM
RSWORDS's Avatar
Here are the part numbers and different rpm defuel specs for some springs.... there are alot more. You can even get a spring to fuel up to 5200 rpm.
1-464-650-386 spring = 2800rpm spring *Stock*
1-464-650-366 spring = 3200rpm spring *Best Over All Mod*
1-464-650-374 spring = 3800rpm spring *May need to trim to Stock Length*need 60 lbs valve springs*
1-464-650-354 srping = 4200rpm spring *May need to trim to Stock Length*need 60 lbs valve springs*
Old Aug 15, 2008 | 03:40 PM
ez_lle71's Avatar
That sounds scary!
ez
Old Aug 15, 2008 | 07:22 PM
RSWORDS's Avatar
Originally Posted by ez_lle71
That sounds scary!
ez
Some guys are working on it. They were for the VE that they used in the VW diesels. The spring mount is a little different but guys are working on it. I would love to get my hands on a VW VE pump.
Old Aug 16, 2008 | 12:19 AM
W150CTDproject's Avatar
A diesel runnin 5 grand or more. I wonder what that sounds like. And What happens when she comes apart
Old Aug 16, 2008 | 12:39 AM
stkdram55's Avatar
watch most of your modified pullin trucks their leavin the line at like 5-6k maybe more the banks sidewinder duramax leaves at like 8000 rpms off the line it sounds ridiculous doenst even sound like a diesel
Old Aug 16, 2008 | 08:40 AM
Begle1's Avatar
The 5000 RPM VE pumps used plungers half the size as our VE pumps; they went faster but moved a lot less fuel.
Old Aug 16, 2008 | 04:54 PM
RSWORDS's Avatar
Yes but if you could get ours to turn 5k.... hmmmmmm... There are secrets to be learned
Old Sep 8, 2008 | 11:17 AM
C/PRD/'s Avatar
Thanks for the #'s RS. Very helpful.
Old Oct 22, 2008 | 05:08 AM
hughesis21's Avatar
who makes our springs 12 valver
