White Smoke?
Old Aug 12, 2008 | 05:59 PM
wilke12V's Avatar
Default White Smoke?
i was at advanced auto with a friend and he wanted to hear my truck at a higher rpm. so while in park i gave it a decent amount of gas and black smoke came out, but he said when i let out of it white smoke came out and i was just wondering how bad (if bad) this is?
stock except exauast
Old Aug 12, 2008 | 06:12 PM
bigdaddydiesel's Avatar
with the age on that vehicle, if it was good and warm, I would think that there is a compression issue, maybe some loose/ bad seals, warn out rings, etc. Maybe time for some freshening up(rebuild kit), Maybe not... Somebody who deals w/ dodges can give you a better answer...
Old Nov 21, 2008 | 03:01 AM
davo79's Avatar
white smoke is generally from carbon buildup on top of the pistons my 95 if im on the road and it idles all night cus its cold and i need the heat will blow white smoke for about 30 miles or so i wouldnt get to worried
Old Nov 21, 2008 | 04:00 PM
BigDiesel359's Avatar
My truck did that as well but it also had no compression in 2 or 3 because it blew through, I just dove into it and replace all the gaskets and seals, but when I was taking the head bolts out, a couple of them seemed looser than others. When I got it apart the head looked great and was still fairly flat and the block was perfect, headgasket didnt have any noticeable damage either. The only thing I can think of is that the head bolts were just loose enough to let the head lift a **** hair.. Would you humor me and try a line torque on your head and see what results come of it?
Old Nov 21, 2008 | 05:19 PM
What year of truck is this? 12V? 24V?
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
