Thermostat Housing Bolt Torque
Old Aug 9, 2008 | 09:36 AM
wildbill's Avatar
Default Thermostat Housing Bolt Torque
What is the required torque on the 3 thermostat housing bolts?
Old Aug 9, 2008 | 10:35 AM
Until tight...
Old Aug 9, 2008 | 12:46 PM
wildbill's Avatar
Old Aug 9, 2008 | 12:48 PM
This is for a third gen?
Old Aug 9, 2008 | 06:38 PM
wildbill's Avatar
I ran em to 130 in/lb and it isn't leaking.
Old Aug 9, 2008 | 06:52 PM
Whit's Avatar
Site Mascot
go till they snap then back off 1/3 turn
I mess with things all day at work and never use a torque wrench.........I just use my own judgment
is this the right answer.......no but its what I do
Old Aug 9, 2008 | 06:59 PM
wildbill's Avatar
Go till they snap. Then back off.
Old Aug 9, 2008 | 09:01 PM
GBWELDING's Avatar
tighten until it don't leak! works for me
Old Aug 19, 2008 | 01:40 AM
usmc0681's Avatar
From the Dodge Ram shop manual:
INSTALLATION
(1) Inspect thermostat seal for cuts or nicks.
Replace if damaged.
(2) Install the thermostat into the groove in the
top of the cylinder head (Fig. 26).
(3) Install the thermostat housing and bolts.
Tighten the bolts to 10 N·m (89 in. lbs.) torque.
(4) Install the radiator upper hose and clamp.
(5) Fill the cooling system with coolant (Refer to 7
- COOLING - STANDARD PROCEDURE).
(6) Connect the battery negative cables.
There ya go. Hope that helps.
jeffersonl
Nov 15, 2015 07:35 PM
Da Bomb
Sep 3, 2015 10:00 AM
Dustin M
May 21, 2015 10:19 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
jeffersonl
Oct 25, 2014 06:46 AM
