6BT/ 13spd? Can It Be Real?
Old Aug 4, 2008 | 10:40 PM
AF1CUMMINS's Avatar
Default 6BT/ 13spd? Can It Be Real?
Hey guys, I saw this link on ebay. Given it is in a Peterbilt, but other than housing issues with the floorboard, is there anything else that would prevent a man from havin one of these setups in our trucks, provided you set up an air supply for it? Needin the opinion of some of you more experienced people here.
eBay Motors: PETERBILT, ROLLBACK, CAR CARRIER, FLATBED,PETE (item 330259101120 end time Aug-11-08 10:53:25 PDT)
Old Aug 5, 2008 | 01:21 AM
01quadcab's Avatar
yeah having to shift that many times would make me not want to do it..
Old Aug 5, 2008 | 01:35 AM
biged681985's Avatar
an adapterplate would be needed. a flywheel. the floorboard would be in the way. clutch.a few other things would be needed to.
Old Aug 5, 2008 | 03:14 AM
stkdram55's Avatar
you would probably lose alot of power trying to turn that tranny, but hey anything is possible
Old Aug 5, 2008 | 04:03 AM
LOGANSTANFORTH's Avatar
it wouldnt be that bad....would be alot easier with a body lift.....if your truck was a 4x4 i would use a floater ford 205 t-case......you wouldnt need an adapter plate, clutch or flywheel.......its already connected to a 6BT cummins...........
and big deal if it burn up some power.....its a p-pump 12 valve.....throw some injectors, DV's, 4GSk, and a turbo on the beast and its ready to roll on down the road.......
if it was a straight 13 speed i would try and find something that i could split the gears with and have a nice 26 gear ranges..........
Old Aug 5, 2008 | 04:13 AM
AF1CUMMINS's Avatar
So Logan, that's a 12V in the pic? Is the flywheel setup and such different on a 24v motor like mine or woud the setup be feasible on my truck with a body lift?
how much power loss are we talkin about here?
Old Aug 5, 2008 | 04:19 AM
you would need everything off the back of that motor to make it work......everything from the back of that 12 valve to the driveshaft yoke on that tranny will be needed......but everything will bolt right up cause its the same motor.......hell you could bolt a turbo 400 chevy or C6 ford behind your truck if you wanted too cause 4BT's came from the factory with them.........there are only like 3 or 4 bolt patterns for those big transmissions and about every diesel engine manufacturer offers an adapter plate to make them work.....
where on base are you at right now?????
Old Aug 5, 2008 | 04:37 AM
AF1CUMMINS's Avatar
bed rock
Old Aug 5, 2008 | 04:41 AM
ahhhhh.......the chairforce.......you need a job with KBR.......it stands for Kick, Back and Relax........its kinda like the airforce.......it involves alot of sleeping and setting around HAHAHAHAHAH
Old Aug 5, 2008 | 05:09 AM
AF1CUMMINS's Avatar
you must be insane, I'm here with Red Horse and we work out a$$es off. We've put up two buildings, extened a taxiway and started building a road and some helicopter ramps just in the time you were gone. Only reason I'm down right now is cuz I tore some ligaments in my ankle.
