Super B Turbo Question/Concern
Old Aug 4, 2008 | 06:44 PM
bjdiesel's Avatar
Default Super B Turbo Question/Concern
hello, I have recently installed a super b turbo. It has about 500 easy miles on it. I was under the hood this past weekend and noticed that when the engine is shut off and the turbo is spooling down there is a clinking noise during the last second of the turbo spool down. I have checked all the bolts for tightness, ensured that oil was getting to it and checked the shaft play and found no front to back play and has no more side to side play than when it was installed and it spins freely. Is something to be concerned with?
Thanks in advance
Old Aug 4, 2008 | 07:59 PM
Whit's Avatar
Site Mascot
are you sure its comming from the turbo??
if the pinwheel rubs the housing it will leave tracks
Old Aug 4, 2008 | 08:04 PM
alpine1jds's Avatar
Being Evaluated
yea doesnt seem like a clunking would be coming from the turbo, check to see if maybe the exhaust isnt knocking on something when it shuts down, maybe get a buddy to help locate the noise
Old Aug 5, 2008 | 11:40 AM
bjdiesel's Avatar
thanks for the responses I have stood at the turbo during shut down and after the engine stops ratteling the turbo still is spinning and sounds fine untill the last second or two then the noise happens. I have sent BD an email last night still waiting for a reply.
I was asked about a chip or programer I have neither. Also the wastegate is set at 30psi. I am changing the oil tonight. Maybe the issue??
also the sound is like a playing card in the spokes of a bike...it kind of ticks in that fashion. like i said earlier it only happens during the last second or two of it spinning.
Old Aug 6, 2008 | 07:01 PM
DB Admin's Avatar
Banned
Spin the fins by hand and see if you hear it ,, also check for play by moving in in all directions , BD will stand behind it ,, if it sounds like a base ball card in bike spokes when spinning it by hand call BD Immediately
Old Aug 8, 2008 | 06:02 PM
bjdiesel's Avatar
I contacted BD have to call back. But I have narrowed the sound down to the heat shield behind the wheel on the exhaust side. It seems to move around and when I clocked it during the installation the heat shield moved out of adjustment(?). I have got it to where it is not making "the noise". I have a trip to make this weekend hopefully it is fixed....
Thanks again for the replys
Old Aug 13, 2008 | 07:53 PM
wtfd6's Avatar
Bombardier
was the turbine housing loose? the only way it can hit is if it is loose or if the thrust bearing is shot.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
