Might Have Found:
Old Jul 29, 2008 | 03:07 PM
wildbill's Avatar
Default Might Have Found:
My boost leak. Is there suppose to be something in this hole? I stuck a piece of wire down it and it went about a 1/2!
Old Jul 29, 2008 | 03:14 PM
Redpatcher0481's Avatar
I don't think that is it. I have the same hole and I don't have a boost leak
Old Jul 29, 2008 | 03:18 PM
Uncle Bubba's Avatar
Just follow the directions in this post and find your leak within minutes. https://www.dieselbombers.com/cummin...tructions.html
Your hose size may be different so you would need the right size pipe to fit but other then that it all works the same.
Old Jul 30, 2008 | 12:36 PM
Nitelord's Avatar
I had a retaining bolt on the fuel lines loose after having the Vp44 replaced. It didn't affect how it ran, but I could hear the pressure leaking down after shutdown. Follow the guide above. That should help you locate the cause.
EverettsGMC
Mar 29, 2015 05:42 PM
klein444
Feb 27, 2015 01:53 PM
blown502
Jan 18, 2015 06:28 PM
SixSpeed
Jan 11, 2015 01:41 AM
The Eddie
21
Dec 21, 2014 02:45 PM
