Speedo Won't Work!! HELP!
Old Jul 24, 2008 | 08:11 PM
W150CTDproject's Avatar
Default Speedo Won't Work!! HELP!
I just bought a 1990 D250, she's bone stock 175,XXX miles but the speedometer doesnt work at all. anyone help me in the right direction to check, manually or electronicly?
Old Jul 24, 2008 | 08:21 PM
carmelo-manic-mechanic@ho's Avatar
if it is a 4x4 check on the transfer case on the drivers side there should be a funny looking box on the upper rear of the case. remove that and look for a square shaft if there isn't one then that is the problem. or if you can't find the speedo box then it may have been nocked off from where you have been driving or the previous person. if it is 2wd it should still be on the driverside rear of the tranny.
Old Jul 25, 2008 | 10:20 AM
ok thanks
Old Aug 6, 2008 | 06:49 PM
stackx2's Avatar
you might need a new vss (vehicle speed sensor)
Old Aug 6, 2008 | 11:08 PM
believe it or not It's in the grid heater wiring. i wired it back to the main harness since sum redneck (im one too but i dont do stuff like this) by passed from the driver side fender well where the wire is visible from the harness directly to the grid heater. Well i took that by pass out and wired it into the main harness and now the speedo bounces to the speed you are traveling at and goes from 10 to your speed fast enough to have an idea how fast you are going. its an on working project.
Old Aug 7, 2008 | 12:11 AM
WinstonWolf's Avatar
... Try the next size smaller
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
cjgregory
Mar 31, 2015 01:45 PM
Cutlass26
Mar 22, 2015 05:46 PM
bonestock
Feb 1, 2015 08:41 PM
Oct 18, 2014 10:10 AM
