Questions On EGTs And Fuel Pressure
Old Jul 23, 2008 | 04:08 PM
outlaw1_gt's Avatar
Default Questions On EGTs And Fuel Pressure
ok i have a 99 ctd quadzilla 120 and open exhaust...
my egts spike to 1000 when i first start out not rompin on it but not totally taking it easy.. and this is with quad off. is this normal? how high can my egts go? how can i bring them down?
as for fuel pressure what is normal? lowest i can go safely?
thanks
Old Jul 23, 2008 | 04:50 PM
Johnny Cetane's Avatar
Are you seeing these numbers with an empty truck and very little throttle? If so then yeah it's a little high if the box is off.
What are you seeing for boost? I would suspect a boost leak first.
You want your FP to be ~15-20 psi IIRC.
Old Jul 23, 2008 | 04:59 PM
outlaw1_gt's Avatar
boost seems normal and the egts pretty much do it givin little or alot off throttle... it does drop down to 600 to 700 after im movin along... mainly at take off..
fuel pressure is lower then that run 10 to 11 at idle... however i do need to change fuel filter this weekend
Old Jul 23, 2008 | 07:01 PM
stkdram55's Avatar
dont let the FP go below 7 psi that is when the VP stops liking you, the EGT thing i would say check for boost leaks like stated above, most likely places would be the boots on the bottom of the intercooler, if you do any off roading a stick can get up in there or a rock or a mazda.
Old Jul 24, 2008 | 12:11 AM
dukeboy_318's Avatar
yeah anything in the 7 or below area is very very very bad,
Old Jul 25, 2008 | 07:28 AM
outlaw1_gt's Avatar
ok i can do that gonna check for boost leak... any other good areas to look? dont do off roading with it so far..
Old Jul 25, 2008 | 08:53 AM
Jazz's Avatar
I can hit 1000 pretty easy with mine when I first take off at medium acceleration but it backs down when boost comes up. I also have some pretty big sticks in it. Might want to check on the air filter too. They need plenty of air.
Old Jul 27, 2008 | 12:49 PM
outlaw1_gt's Avatar
ok cant see any leaks, air filter is good..
Old Sep 3, 2008 | 11:37 PM
brianell's Avatar
I saw higher EGT's running a weak actuator, not boosting as much as it should, so check out your boost too. See my thread for what I went through (only 17psi boost, etc thread title)
Old Sep 4, 2008 | 12:34 AM
2500ho2's Avatar
you can take your egt up to 1150*F but only for a short time or else you could melt down #6 piston, as for fuel pressure the debate is still open as to how low to go, when I'm in the throttle I don't let it get below 5lbs, boost is usually 24-28 lbs but had it up to 32 going up antler hill north of innisfail
