Amsoil Visit - Amsoil
New Things From AMSOIL
Old Jul 22, 2008 | 07:22 PM
Heath's Avatar
Authorized Amsoil Dealer
Default New Things From AMSOIL
Just got back from the 35th anniversay convention. Quite the show they put on. Thought I would fill you in on some new things coming out. Some related to diesels, some not
For the diesels, this fall, they will have a combination of the diesel concentrate and the cold flow improver. Currently they are separate products, but those of us in the northern states will benefit from this combo.
There will be an EaA air filter(stock replacement) for the 6.7L cummins this fall as well.
The Injen air intakes...new model year fits will be coming out. Bad news is there will be no older model years being made. They will be coming out with 16 models for gassers as well.
They are finally coming out with a synthetic power steering fluid. It will be a universal fluid covering most appl. that don't use ATF.
Other new items that are now available....
10W-30 motorcycle oil, used in the newer Goldwings
a 15W-50, 10W-30, and 5W-20 Dominator racing oils
I think that covers it.
Heath
Old Jul 22, 2008 | 07:30 PM
mikmaze's Avatar
sounds pretty slick......... thanks.
Old Jul 23, 2008 | 08:17 AM
CumminsCrazed's Avatar
so for the injen intakes......are we talking a NO for us 2nd gen guys Heath?
Old Jul 23, 2008 | 09:20 AM
Heath's Avatar
That is correct
Old Jul 23, 2008 | 11:38 AM
PettyVTX's Avatar
Goldwing oil will be nice
Old Jul 23, 2008 | 07:19 PM
RodZZilla's Avatar
WhiskeyRiver took my mind
Nothing for the REAL LLY either?
Old Jul 23, 2008 | 09:41 PM
Heath's Avatar
Rod, this thing has had me baffled since you mentioned it. It think I'm getting a handle on it now??
Am I correct in saying the 05 LLY has two different engines and the 8th digit in the VIN tells which one? And apparently the intake will work if that letter is a D and won't if it's not?
If that is the case, you are so right that this is not very clear at all.
Old Jul 23, 2008 | 09:57 PM
RodZZilla's Avatar
The 05 LLY has a different turbo inlet than the 06 LLY and LBZ. The 04.5 and 05 LLY's have a 2 as the 8th digit on the VIN. Their instructions say LB7. I am not sure what the 06-07's have as the 8th digit. Must be the D.
05-07 Chevy Duramax V8 6.6L LBZ, LL
(VIN D) see 8th digit VIN
Will not fit 2004-05 LB7 (VIN 2)
Should state 06-07 LBZ, LLY
Will not fit 2004.5-05 LLY
The LB7 was the 2001-2004 series.
Old Jul 23, 2008 | 11:34 PM
01quadcab's Avatar
they are really missing the boat on this there are a ton of 2nd gen dodges that would be going for this and sure a lot of guys haven't yet purchased cold air intakes for their trucks and these look good. plus all the dmax guys out there too
Old Jul 25, 2008 | 08:32 AM
Marine's Avatar
I am waiting for KTM oil filters.
I am also waiting for the new PS fluid for my hydraulic winch.
