Transmission Problems 47RE
Old Jul 21, 2008 | 10:02 PM
roadgold640's Avatar
Default Transmission Problems 47RE
when truck is first put into drive or reverse at idle engine dies. this only happens when it is first started up. Trans is new from ATS W/5 disk converter. I was having this problem before the new transmission was put in .
Old Jul 21, 2008 | 10:07 PM
Benjamin's Avatar
Bombardier
what is your idle set at?
Old Jul 21, 2008 | 10:11 PM
800rpm
Old Jul 21, 2008 | 10:13 PM
Most the time this happens it is due to a tight torque converter.
Old Jul 21, 2008 | 10:15 PM
truck is basicly stock 4" Dynomax exhaust pod trans temp,EGT,Boost,FP Guages Powerpuck Airdog 100 to be installed this weekend
Benjamin's Avatar
Bombardier
try it at 1000 or 1100 in neutral. with that 5-star converter there is alot of rotating mass and if the converter is a tight one to begin with then it'll drop the rpm 200-300 when it engages in gear. if that dosen't work it sounds like you might be having some wiring problems and the converter may be locking once it is places in gear. a stock converter will stall a motor so i know a 5 clutch one will even faster.....
Old Jul 21, 2008 | 10:16 PM
Tight as in ?
Benjamin's Avatar
Bombardier
NOTE - is the idle adjustable on a VP44 truck like a 12valve?
Originally Posted by roadgold640
Tight as in ?
a lower stall speed
the stock converter is loose and 99% of all aftermarket ones are alot tighter than the stockers and make the motor work harder in the lower RPM's
Old Jul 21, 2008 | 10:20 PM
I had this problem with the old 3 disk also. I have a manual lockup switch it is not like it is locking up it is stalling. How do I raise the idle ?
Old Jul 21, 2008 | 10:31 PM
Benjamin's Avatar
Bombardier
idle is computer controlled. you'll have to get the dealer to reflash it
here is the TSB for the reflash if the problems were occurring when it was stock
TSB 18-015-00 Rev A - reflash PCM
