View Poll Results: Whats Causing the Surge
Adrenaline
23.08%
MAP Sensor
7.69%
VP44
7.69%
APPS
61.54%
Injectors
0%
Transmission / TC / VB
0%
Voters: 13. You may not vote on this poll
Surge Issues
Old Jul 19, 2008 | 03:55 PM
FormerVendor
Default Surge Issues
Ok ive been having some issues with my truck. Its got some surge at light throttle. No Dead Petal just surge. The stronger the tune on the Quad Adrenaline the worse the surge. It also surges when ive got the Quad set on level 0. It surges weather the truck is warm or cold. It really surges bad with the Adrenaline on when I lug the truck. I have tried several different tunes and it still surges. When it begines to surge at light throttle if I roll into the throttle the surge is gone.
Lets take a guess on what you guys think the probelm may be.
No Codes
Old Jul 19, 2008 | 04:03 PM
Uncle Bubba's Avatar
The beginning stages of the APPS being out of adjustment. It turned into the occasional dead pedal on mine after a while and doing the APPS Adjustment I found out it was way out of specs. Put it back to the right setting and has never done it since.
Or fuel delivery problems be it the LP or a dirty filter.
Old Jul 19, 2008 | 04:12 PM
FormerVendor
Ya APPS was my first thought. Ive got a new LP and new filters.
I was meaning for the other option on my poll to be APPS.
Old Jul 19, 2008 | 06:08 PM
dukeboy_318's Avatar
might also be fueling too much without enough timing, too much fuel can put the fire out as well.
Old Jul 19, 2008 | 07:38 PM
FormerVendor
I'm going to do the quick APPS reset tomorrow. If that doesnt help then I will check the voltage on the APPS and adjust if needed.
Old Jul 19, 2008 | 11:25 PM
DB Admin's Avatar
Banned
I had the surge , Its improper matching of Programmer, Turbo , injectors Torque Converter
The Adrenaline on 6 and i have almost no surge at all ,
With the smarty my head would hit the roof of my truck on all settings
Old Jul 19, 2008 | 11:57 PM
FormerVendor
Ya I have tried almost every tune Quad has and mine still surges. This is why I dont think its the Adrenaline.
Old Jul 20, 2008 | 12:09 PM
OneBadBia's Avatar
I'm a girl!
I had that same issue with my truck when I had nothing but my quad box on it. I called quad and they told me that they can re flash it for me but they cant guarantee that it will fix anything. He said to check the voltage to my map sensor to make sure it was good and other than that he said no matter what they have done some truck's just do it. He offered to let me go to their shop where they would pull my box off, put it on another truck and see if it would do it on that truck but he also said the only vp truck they have there almost never surges.
Old Jul 20, 2008 | 02:33 PM
FormerVendor
Well im going to check my MAP and APPS and see what I find.
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
ronstop
Feb 26, 2015 09:48 AM
rrough96
Feb 21, 2015 11:26 AM
Polaris04
Dec 1, 2014 08:27 AM
