#1 Injector Line Felt Something Like A Tapping????
Old Jul 19, 2008 | 12:11 PM
wildbill's Avatar
Default #1 Injector Line Felt Something Like A Tapping????
So I was under the hood fixing a leaking oil pressure sender and I was feeling up the injector lines, out of curiosity. Anyway #1 has kind of a tapping to it, while the others run smooth. Any ideas?
Old Jul 20, 2008 | 02:12 AM
2500HeavyDuty's Avatar
do what now?
Old Jul 20, 2008 | 11:39 AM
06 DIESEL's Avatar
I am not sure what this could be truthfully, but I think that you just made the best on members quote thread. I will look at mine today and see if I have similar symptoms.
Old Jul 20, 2008 | 12:42 PM
wildbill's Avatar
I'd appreciate that.
Old Jul 21, 2008 | 03:01 AM
dalton06's Avatar
mine does the same thing. It also has a brief ticking sound then fades out maybe 30 seconds after being started. I've wondered about both of the issues?
Old Jul 21, 2008 | 05:19 AM
wildbill's Avatar
Same thing here.
Old Jul 21, 2008 | 07:48 AM
mysterync's Avatar
It can be a sign of injector failure. Or it can just be the pressure, I would diagnose it with a Solus Pro, Turn that injector off and go from there!
Old Jul 21, 2008 | 08:41 AM
wildbill's Avatar
I had a cylinder kill test done, oh about a month ago. Said all the injectors were working. I suppose much could happen between then and now.
Old Jul 21, 2008 | 09:38 AM
mysterync's Avatar
Are you currently having any symptoms of injector or pump failure? Most Likely it's just fine. A Little bit of Air or airated fuel can cause a Water hammer effect.
I understand your concern ....This bosch common rail stuff is getting silly...and silly expensive!
Old Jul 21, 2008 | 09:43 AM
wildbill's Avatar
EPA is getting silly to, but that's a whole 'nother can of worms there. You mentioned something about a Solus Pro?
